Post by bobdragon12 on May 19, 2014 15:14:43 GMT 1
I need to repair the A post front scuttle areas on both sides of my transit . this I know is not an uncommon situation and getting new sections to weld is not easy either , but I do a lot of work in China and have spent a 6 weeks out there in the last year and have access to metal pressing factories so I'm contemplating getting tools made to re produce these parts if the price is right and I'm sure there would be a great demand for these or other panels if it goes OK . so I'm on the scronge does any one have a pair to sell or loan they don't have to be perfect ?
Post by irishtransit on May 19, 2014 19:59:58 GMT 1
good luck with your venture,it's things like this that we need to keep our vans on the road.
Post by muttleymk2 on May 19, 2014 20:24:13 GMT 1
Do you mean the actual windscreen surround and A post, its all one panel.
Post by bobdragon12 on May 19, 2014 20:47:09 GMT 1
Well I. Thinking repair sections of each end as it seems to be mainly the ends and tooling for the complete scuttle would be really expensive . Thoughts appreciated
Post by muttleymk2 on May 19, 2014 20:53:25 GMT 1
What I mean is that you cant get the bits you need for the repair sections without cutting up a surround panel
Post by bobdragon12 on May 19, 2014 21:01:31 GMT 1
No I understand that , to be honest all I actually need is a bad section that has been cut away nicely that can be filled etc to make the top face good .
Post by muttleymk2 on May 20, 2014 19:44:17 GMT 1
I am about to do one of Fred's I will see if I can cut 'em out in one
Post by bobdragon12 on May 20, 2014 21:01:13 GMT 1
Would be appreciated , if I have a good one I might be able to Draw it up in CAD . Just seen what I can do to help others
Post by sidewaysjas on May 20, 2014 22:28:56 GMT 1
I think if you could make those you would sell them to every mk1/2 owner, good luck Jas
Deleted
Deleted Member
Post by Deleted on May 22, 2014 22:54:58 GMT 1
Intresting thread. I just did my lower screen corners last week.
I had no choice but to shape some sheet metal, cut the rust and weld in my newly made pieces It was hard to get all the angles as it curves in 3 directions at the lower screen corner but possible with a hammer and dolly.
Intrested to see if you can produce these in batch form, you'd sell them like hot cakes!
aussiebob
New Star
gday group i own a 79 sundowner auto emerald green currently off road for restoration
Post by aussiebob on Jul 10, 2014 6:35:07 GMT 1
i am about to fit a replacement rear wheel arch panel and the lower rear panel on my transit before i bugger it up any suggestions on the best way to attack this job. Regards Bob
Post by conrod on Jul 11, 2014 1:12:29 GMT 1
i am about to fit a replacement rear wheel arch panel and the lower rear panel on my transit before i bugger it up any suggestions on the best way to attack this job. Regards Bob sorry to go OT, but would love to see a few pics of your van Bob Conrad
