Post by troppo on Jul 20, 2014 23:47:41 GMT 1
G`day folks Have any of you used the electric power steering from a corsa/barina on a MKII? If so do you have any advice or build pics? Cheers Troppo
Post by conrod on Jul 21, 2014 3:05:20 GMT 1
Post by troppo on Jul 21, 2014 4:27:54 GMT 1
I`ll have a look around the wreckers and see what i can find, i just dont need the hassle of the electronics and it seems that thats needed to make them work
Post by conrod on Jul 21, 2014 5:22:41 GMT 1
I think you will need an electronic box to make any of the electric steering columns work.
Post by troppo on Jul 21, 2014 5:50:11 GMT 1
Yeah thats what i heard, might have to look for a MKIII power steering box
Post by conrod on Jul 21, 2014 6:08:22 GMT 1
got one of those for my Mk1: Is the steering heavy in your van?
Post by troppo on Jul 21, 2014 6:11:32 GMT 1
Yeah fairly heavy, but i have a fair load in the back right now. Its just a bitch in carparks, loaded or not
Post by conrod on Jul 21, 2014 6:20:30 GMT 1
guess I will find out in a few weeks when mine turns up! Those 4.1's are heavy donks, especially with an iron head! PS box might get diverted from the Mk1.......
Post by southhem on Jul 22, 2014 23:13:01 GMT 1
Just thinking through the power steering options. Surely the electronic assistance relies on purely assistant the shaft to turn easier......leaving the same no of turns from lock to lock.......which is one of the main reasons to switch to a proper oil assisted box. So that you don't have to turn the wheel a dozen times to steer the van. Just a thought.
Post by conrod on Jul 22, 2014 23:45:05 GMT 1
Yes of course, the electronic assist still uses the same steering box, so the same number of turns lock to lock (about 5.5 in a Transit?) I think the Mk3 PS box is about 3.5 turns.
But I am not sure that all people are necessarily after a quicker steering though, just a system that would make parking a bit easier?
Conrad
Post by dodgerover on Jul 23, 2014 11:03:06 GMT 1
Apparently Fiat's also use an electronic PS system similar to the MG, Corsa/ Barina etc which can be used, TidyTom has a proper transit PS box for sale on here, shipping might be a bit of a dear do though.
As far as i know all the electronic systems need a seperate box to fool the system into life, most just give you a trimmer to adjust the level of assistance required but a few you can add on speed sensors etc so you don't get ultra light steering once you are rolling. I had a Corsa Van as my work van prior to the transit and it is a good system as standard, the only fault i found was on a mates van and that was due to lack of maintenence by a previous owner.
