Deleted
Deleted Member
Post by Deleted on Aug 27, 2014 6:57:03 GMT 1
Mk2 chassis cab/tipper fitted with Di
After finally getting round to fixing my leaking screen rubber I'm now in a position the attempt to quiten the Dis prehistoric drone.
There seems to be a barrage of choice out there, so much so I'm left confused as to which product to buy!!!
I originally thought dynomat simply because I've heard the name used a few times.
I'm having to weigh up the comfort of such an install, the fact the van is my daily work vehicle it's quite important. Also I'm not keen on self adhesive foam as I want to periodically lift and check for rust, clean it and to check no more water is getting in. Also price is an issue I'm happy to spend money on the right product but don't want to throw money away so to speak.
I'm fitting a 4.63 diff in place of the current 5.14 so this should have lower noise levels a little. But currently it's 80-90db at 50mph in there!!!
I wear ear plugs currently which are -39db but it's not really the solution especially with passengers.
Any advise would be greatly appreciated.
Post by jonochap on Aug 27, 2014 7:55:50 GMT 1
There are some good videos on you tube about deadening...whether its foam, paint or tile. I didnt have the cash so used roofing material in the bay. If you can afford dynomat or the paint then i would do it. But under the carpeting and in the doors is a bit of a fiddle If its not broken...I can break it!
