Post by irishtransit on Oct 1, 2014 13:43:26 GMT 1
never done this before so how do I remove the rear windows on me van?do they just push out or do I prisee them out with a screwdriver?
Post by jonochap on Oct 1, 2014 15:19:44 GMT 1
Do you want to put them back after???
Post by Ralph on Oct 1, 2014 18:00:47 GMT 1
Push them out from the inside.
Post by irishtransit on Oct 1, 2014 19:01:38 GMT 1
cheers ralph. jono that would be the aim but i'm not great with glass.
next question.the door handle on the rear door is it held on with Philips head screws or pozzi drive?whichever it's seized!!
Post by dodgerover on Oct 1, 2014 19:09:19 GMT 1
If you need it have back door glass, also have ambulance back door glass (double panes). Both free if you want them
Post by irishtransit on Oct 1, 2014 19:30:56 GMT 1
If you need it have back door glass, also have ambulance back door glass (double panes). Both free if you want them thank you very much for the offer but at the moment i'm alright for the camper glass as I have a spare door.the amby glass would be handy for old Jackie but the cost is getting it to here or kent.
Post by jonochap on Oct 1, 2014 21:09:34 GMT 1
jono that would be the aim but i'm not great with glass. Just helping with removal ideas
Post by kerryb on Oct 2, 2014 7:11:00 GMT 1
Use washing up liquid and water in a trigger bottle ( for spraying water or use a cleaned out surface cleaner one etc ), spray the edge that you are going to start with and use a flat headed screwdriver ( if you don't mind scratching the paint ) you can wrap tape around the flat edge of the screwdriver to minimise damage. Pry a corner over from the inside and gently make your way around the window, using the spray bottle lots to keep it all moist. If you warm the rubber first with hot ( not boiling ) water this helps soften the rubber making it easier to move. Just take your time and don't be tempted to force the glass out, when you have one side removed remember to hold onto the glass, it will be slippery with the washing up liquid. I have known people to duck tape glass with a loose cross, corner to corner, gives enough room to pop the rubber out but holds the glass. Good luck. If using new seals on refit you can just cut the old seals with a blade, but again, take your time, a minute longer could save you money, hassle or a trip to your local A&E department !
Post by irishtransit on Oct 2, 2014 19:28:51 GMT 1
managed to get them out without breaking them,yaayyy. had to drill the handle off as the screws were seized.
Post by dodgerover on Oct 2, 2014 19:54:44 GMT 1
Frighteningly easy to get them out isn't it? Thats one reason why i don't have them any more. I think i could have one out silently in seconds if I didn't want to save the rubber
