Post by troppo on Dec 19, 2014 6:37:06 GMT 1
G`day guys I had the bonnet pop open a couple of years ago and bent the rear corners (i`ve heard this isnt all that uncommon). My question is: can anyone walk me through the process of repairing the bonnet so it looks right again? Cheers all Troppo
Post by FredTransit on Dec 19, 2014 10:38:42 GMT 1
Big hammer? Have you got the hook on it to stop it coming up?
Post by troppo on Dec 19, 2014 22:27:28 GMT 1
I did, but it was jammed open and i didnt know. Silly bloody idiot i am
Post by dodgerover on Dec 19, 2014 23:28:37 GMT 1
Block of wood underneath the crease and apply force in the opposite direction to that which initially bent it to bring it back, failing that gentle application of a hammer to bring them back down. You might need to do final adjustment in situ to get them as close as possible
Post by irishtransit on Dec 19, 2014 23:28:56 GMT 1
personally depending on how bad I'd get a pair of multi grips and a couple of bits of wood.plac the wood on top and below the bend and tighten the grips onto the timber as not to damage the bonnet and then bend down until straight.tidy up with a bit of filler and bobs ya uncle.
Post by troppo on Dec 20, 2014 4:51:24 GMT 1
Cheers guys, you pretty backed up what i was thinking. I thought someone might have some magic trick that made super simple
Post by dodgerover on Dec 21, 2014 18:20:56 GMT 1
Cheers guys, you pretty backed up what i was thinking. I thought someone might have some magic trick that made super simple Used replacement - works most times!
Post by troppo on Dec 23, 2014 1:01:00 GMT 1
they are non existant down here, would be easier to find unicorn sh!t
