Post by jonochap on Apr 12, 2015 11:54:17 GMT 1
Lovin it
Post by retiredtruckie on Apr 12, 2015 12:00:36 GMT 1
Looking good matey
Post by FredTransit on Apr 12, 2015 16:16:52 GMT 1
Nice floor! Where did your early pics go?
Post by bimmerbrother on Apr 13, 2015 17:19:22 GMT 1
I don't know what happened, a lot of pics were removed from Photobucket. Luckely I could replace them, they were still on the computer.
Post by bimmerbrother on May 24, 2015 9:00:40 GMT 1
With a silver lining. Trying to repair the doorstep.... I took it out (to much work.)
And replaced it.
Post by bimmerbrother on May 24, 2015 9:03:56 GMT 1
Started on the engine too, it ran nice but was leaking oil a lot, so it's mostly replacing seals and gaskets.
Post by irishtransit on May 24, 2015 19:15:45 GMT 1
She looks well nice.
Post by troppo on May 25, 2015 2:26:27 GMT 1
That engine cleaned up nicely, whats your secret on the alloy parts?
Post by bimmerbrother on May 25, 2015 11:17:53 GMT 1
I sandblast all the alloy parts so they are rough. Then I polish them a bit with a brass wirebrush to smoothen them a bit and spraypaint them with a aluminium paint. This paint isn't good enough for parts you want to look chrome but for a alloy finish it is. The trick with the alloy paint from a spraycan is to let it sit after painting for a day or two to keep the gloss.
Post by retiredtruckie on May 25, 2015 12:05:17 GMT 1
Looks good and very clean too
Post by troppo on May 25, 2015 19:22:19 GMT 1
I sandblast all the alloy parts so they are rough. Then I polish them a bit with a brass wirebrush to smoothen them a bit and spraypaint them with a aluminium paint. This paint isn't good enough for parts you want to look chrome but for a alloy finish it is. The trick with the alloy paint from a spraycan is to let it sit after painting for a day or two to keep the gloss. Great tip about leaving it for a couple of days, i degreased all my alloy and then soda blasted themthey came up nice but yours look much more even and consistant
Post by bimmerbrother on May 29, 2015 20:22:50 GMT 1
Boring job.....
The valves back in.
Nice touch!
I've replaced the original inlet for one from a Escort RS2000 and a 32/32mm carb from a 2.0 V6 engine....will that work??
Post by bimmerbrother on Jun 18, 2015 19:48:42 GMT 1
The headgasket and bolts arrived so I could finish it.
I had some work making the Solex functional, I replaced the waterhousing for the auto-choke to get the right diameter for the hoses, welded the lever pick up from the old carb on the Solex and lowered the cable support on the inlet.
Because the carb didn't came with a filter I made my own. If this will work I don't know but I'll find out when it's running.
Behind my back the Mk1 is coming along too.
Post by irishtransit on Jun 18, 2015 20:42:10 GMT 1
Nice looking work alround.
Post by bimmerbrother on Jun 18, 2015 21:02:16 GMT 1
That should add some Sparks!
