Post by mrgrimly on Feb 3, 2015 20:10:02 GMT 1
Stunning, beautiful work
Post by jonochap on Feb 3, 2015 20:20:18 GMT 1
This is great. I'm now working on a devious cunning plan to get you to not only give me those air bags but also fit them for me! I'd be able to get my van into my garage with that. Get back in line ditch!
Post by suolamk1 on Feb 8, 2015 21:52:01 GMT 1
Hahaha. I think here is that them bags are staying here . Bags actually aint expensive , go and buy a pair or two, your transit is gona lose some weight omif you install them and ditch the leafs. Should give a smooth ride too, they say..
Post by jonochap on Feb 8, 2015 23:16:10 GMT 1
When i was looking i was struggling to get it lower than 500 bucks
Post by supersport on Feb 8, 2015 23:27:01 GMT 1
need more pics of the fabrication work.
Post by suolamk1 on Feb 9, 2015 16:17:41 GMT 1
Pics are pretty much there .. Bags were about five yeah, but omg all the bits and peaces the wallet gets thinner about the twice.. It has taken about 95m of wiring and tubing also, but almost done here.. Need to find some sort of air dryer after water separator for the system and then just connect about 20 wires, THEN finnish so it looks decent.. Fewh! Forgot that my air tank is still not mounted.. Aargh. Just when you think it should be there and straight away somethings gonna pop to your head and press you underground again..
Post by jonochap on Feb 9, 2015 20:27:21 GMT 1
Due respect hombre
Post by suolamk1 on Feb 12, 2015 7:58:52 GMT 1
Cheers mate!
Deleted
Deleted Member
Post by Deleted on Feb 12, 2015 22:55:29 GMT 1
Lovely fabrication work there.
What size wheels are those. Look bigger than 14"s?
Post by suolamk1 on Feb 13, 2015 15:02:47 GMT 1
Very many thanks! Them are sixteens taken from iveco twin wheeler, bolt pattern ok but needs a fitting ring..
Deleted
Deleted Member
Post by Deleted on Feb 14, 2015 11:13:43 GMT 1
Very many thanks! Them are sixteens taken from iveco twin wheeler, bolt pattern ok but needs a fitting ring.. Do you mean the chamfered washers split washers that go on the studs before the inner wheel goes on? I'm very interested in this option as I desperately want to go bigger than the 14"s
Post by suolamk1 on Feb 15, 2015 16:53:09 GMT 1
i mean fitment ring to center the wheel but those washers are which centers in this case? have not checked those yet :/
Deleted
Deleted Member
Post by Deleted on Feb 16, 2015 8:48:31 GMT 1
i mean fitment ring to center the wheel but those washers are which centers in this case? have not checked those yet :/ I think we're talking about the same thing!? Maybe someone can clarify? The 'rings' I'm talking about go on each stud (they are chamfered washers with a cut) these go on against the hub before the inner wheel is fitted. As far as aware there is not a center locating ring like you would get on some car alloys.
Post by suolamk1 on Feb 16, 2015 14:45:28 GMT 1
Yes same washers.
Post by suolamk1 on Apr 24, 2015 6:12:28 GMT 1
First front lift wirh bags
