Post by troppo on Mar 10, 2015 7:59:48 GMT 1
G`day folks Finally got started on the van, over the last week i`ve stripped the engine bay (my back wont let me work for more than a half an hour or so before it gives out on me, so what used to be a few hours work has turned into a weeks work). Stripped out all accessories and bolt on parts, only need to drop the tailshaft and disconnect the transmission linkages. Heres where i am so far And the tight squeeze in the trans tunnel As you can see its damned oily, its going to get all external gaskets replaced and an aerosol rebuild, a good trans service and the engine bay stripped, all rust repaired and painted in the original white. Going to be a fairly long process with my back but it will happen, got an electronic dizzy to fit and will clean up all odd holes in the engine bay. My plan is to do all the door interiors and jambs before i get started on the exterior of the old girl. Well enough of boring you, catch you round the boards. Cheers Troppo
Post by troppo on Mar 17, 2015 8:29:16 GMT 1
OK finally got the engine and trans out,yes i know it has taken a while but when my back says i need to stop i need to stop, so i cant do more than a half an hour or so at a time. Anyway i got a real surprise, it looks like i have a reco trans which is a bonus (it might lok a little grubby but the pan gasket was brand new, rear seal is too and the fluid looked like it came straight out of the bottle). saves me a lot of work. can you spot the leaks? lol So next i split the engine and trans and get to work with gaskets and aerosols for the engine rebuild then prep and paint the engine bay. Cheers all Troppo
Post by jonochap on Mar 17, 2015 14:31:30 GMT 1
Lummy, thats a fair sized lump
Post by FredTransit on Mar 17, 2015 16:52:23 GMT 1
Whoa straight six!
Post by troppo on Mar 17, 2015 17:02:45 GMT 1
Lummy, thats a fair sized lump yep. made it a real bitch to get it out Yep only has 3 1/2 pistons showing past the trans tunnel
Post by jonochap on Mar 17, 2015 20:26:20 GMT 1
Is that good or bad?
Post by troppo on Mar 17, 2015 20:52:46 GMT 1
well, its a 250ci crossflow, a lot bigger (in capacity) and more powerful than a pinto so there are pro`s and cons. It has more power and torque than a pinto which is good for when the backs full of crap, but on the other hand it uses a fair bit more fuel than a pinto and its a bitch to work on the back 3 cyls (even with the cabin hatch open). Its got a C4 trans behind it and though its geared fairly low it will pull like nobody`s business. The one thing i dont like is the fact that it is geared so low, it starts to scream at about 110kmh (about 66mph)but apart from the transmision they are all original parts and the speedo reads pretty much spot on so i really mustnt grumble
Post by sidewaysjas on Mar 17, 2015 22:50:38 GMT 1
Interesting van mate, keep at it.
Jas
Post by retiredtruckie on Mar 18, 2015 4:51:25 GMT 1
You were lucky to score a c4 trans didn't most of them come out with the Borg Warner box?
Post by troppo on Mar 18, 2015 5:15:38 GMT 1
Looks like the manual i have says the C4 was standard, doesnt have any other trans options other than a three speed manual. There may be differences in other models.
Post by retiredtruckie on Mar 18, 2015 5:23:43 GMT 1
Yeah they are the stronger box makes sense really
Post by troppo on Mar 18, 2015 23:12:47 GMT 1
Yeah they are the stronger box makes sense really Going to give it a service since its out, and a bit of a clean up. Cant work out why its got that patch of muck on top of it though. Going to replace all the trans cooler lines as all the rubber sections are shagged and one of the bundy tubes has a kink in it. Then its on to the big job, degreasing the block, going to be a three or four step process i reckon. Cheers Troppo
Post by dodgerover on Mar 18, 2015 23:39:02 GMT 1
well, its a 250ci crossflow, a lot bigger (in capacity) and more powerful than a pinto so there are pro`s and cons. It has more power and torque than a pinto which is good for when the backs full of crap, but on the other hand it uses a fair bit more fuel than a pinto and its a bitch to work on the back 3 cyls (even with the cabin hatch open). Its got a C4 trans behind it and though its geared fairly low it will pull like nobody`s business. The one thing i dont like is the fact that it is geared so low, it starts to scream at about 110kmh (about 66mph)but apart from the transmision they are all original parts and the speedo reads pretty much spot on so i really mustnt grumble I doubt anything other than a big block could use much more fuel than a pinto dragging a fully loaded LWB ....Are the alloy head 4.1s much better on fuel than the iron heads? - from memory we used to regularly get well over 8km/l on gas with our old XF sedan even when it was loaded to the roof
Post by troppo on Mar 19, 2015 0:52:33 GMT 1
I doubt anything other than a big block could use much more fuel than a pinto dragging a fully loaded LWB ....Are the alloy head 4.1s much better on fuel than the iron heads? - from memory we used to regularly get well over 8km/l on gas with our old XF sedan even when it was loaded to the roof I dont think the cast iron heads are all that much less efficient, i`m going to port match the heads and manifolds which hopefully will give me a few mpgs extra. Not going to be fun, i hate grinding cast iron
Post by troppo on Mar 22, 2015 8:56:32 GMT 1
Well spent the last couple of days giving the engine a bath (cant do too much at a time because of my back) and couldnt believe the change, definately needs a set of gaskets i think before after When i pulled the trans off the engine i was confronted with a brand new torque converter so i`m sure its had a fully reco`d trans in it recently. Progress may be a little slow but progress is progress
