Post by buxvan on Mar 25, 2015 15:06:45 GMT 1
Just wondering if anyone knows the dimensions of a mk2 front hub oil seal. I need a pair, I know you can buy the bearing kit c/w oil seal but my bearings are fine.
Post by troppo on Mar 25, 2015 22:15:47 GMT 1
Just take one of the old seals to a bearing supplier or a decent car parts place, they should be able to match it up easy enough
Post by buxvan on Mar 25, 2015 23:22:22 GMT 1
Thanks for the reply troppo. The depth & outside width are easy to measure but the problem is the lip diameter. If I had that I could order them from the old internet ! O/d is 60, depth is 9mm but unsure where to measure for inside diameter. Thanks again. Buxvan
