Post by retiredtruckie on May 9, 2016 7:04:35 GMT 1
Well done
Post by jonochap on May 9, 2016 21:50:00 GMT 1
Front springs are a mare, mutts did a great job fabricating Spring helped for puk, huge difference
Post by rick on May 9, 2016 23:11:21 GMT 1
Front springs are a mare, mutts did a great job fabricating Spring helped for puk, huge difference I've been told about a local company that might be able to help but we'll see ☺
Post by rick on May 9, 2016 23:18:59 GMT 1
Post by stoney on May 17, 2016 10:43:52 GMT 1
I've managed to find some trim now by the meter and at a very reasonable price compared thanks for the info you both put me on the the right track I'd been searching for seal when actually what I wanted to be looking for was called fender trim I've ordered it from a company called bridge rubber and plastics. Mean while I've been working front to back I've come across a broken spacer? Is it a common part or am I better looking for something to do the same job? The plastic spacer thing should be there its a guide/roller for the rear sliding springs, I just bought some nylon rod of the same outer diameter and drilled the inner to match the mounting bolt.
Post by rick on May 21, 2016 6:28:50 GMT 1
I've managed to find some trim now by the meter and at a very reasonable price compared thanks for the info you both put me on the the right track I'd been searching for seal when actually what I wanted to be looking for was called fender trim I've ordered it from a company called bridge rubber and plastics. Mean while I've been working front to back I've come across a broken spacer? Is it a common part or am I better looking for something to do the same job? The plastic spacer thing should be there its a guide/roller for the rear sliding springs, I just bought some nylon rod of the same outer diameter and drilled the inner to match the mounting bolt. Thanks for the info mate I'll put it back on my to do list it's obviously not major as it didn't get picked up on the mot :-)
Post by rick on May 23, 2016 8:54:51 GMT 1
He managed a 40 mile round trip yesterday my little lad loved it
Post by jonochap on May 23, 2016 17:30:36 GMT 1
You must be chuffed well done!!
Post by rick on May 24, 2016 21:37:20 GMT 1
I am mate :-) to get it usable has been the main aim ;-)
Post by rick on May 26, 2016 23:26:01 GMT 1
Post by bullsintransit on May 27, 2016 14:33:46 GMT 1
Looks really good.Do the doors to front cupboards form a screen from cab when both open? Colours and pattern of cushions, curtains look proper period,without going the bright orange,lairy flower route,choice choice.
Post by rick on May 27, 2016 15:11:26 GMT 1
Cheer mate..... Yes they do the mirror needs taking off the right cupboard as it makes it hard to close.
I want to keep it quite period looking if I can that's the plan anyway ☺ the back end still needs attention but I'm getting there slowly now
Post by retiredtruckie on May 29, 2016 12:14:17 GMT 1
Looking real good rick well done
Post by irishtransit on May 29, 2016 15:40:28 GMT 1
that's a very nice looking van indeed.
Post by rick on May 29, 2016 17:22:08 GMT 1
Thanks I'm really pleased we can start and use it now it's never going to be mint I don't intend it to be but I'll get it as clean as poss ;-)
