Post by seaneylad on Jun 22, 2015 7:58:07 GMT 1
Post by FredTransit on Jun 22, 2015 8:48:14 GMT 1
I am pretty sure that's a Lomas. Ours (S reg) has some kind of car lights too. Our Hanlon and Wadham have generic bus type lights. The only thing on yours I would worry about is the scuttle/windscreen surround. On a normal van it's not too bad, with an amby it's a mission! Still possible though. Just pop rivet a plate to the original gearlever hole.
Post by seaneylad on Jun 22, 2015 8:57:01 GMT 1
I am pretty sure that's a Lomas. Ours (S reg) has some kind of car lights too. Our Hanlon and Wadham have generic bus type lights. The only thing on yours I would worry about is the scuttle/windscreen surround. On a normal van it's not too bad, with an amby it's a mission! Still possible though. Just pop rivet a plate to the original gearlever hole. Cool, what colour white where they do you know name or colour code? Yeah the A pillars and around windscreen is rotten bad! the scuttle itself is new i believe and pretty solid... Would it be possile to pull beading where fibreglass box meets top of screen, cut out pillars as best possible weld some new ones (well 2nd hand) if i manage to get a set. The other parts that need welding wont be to bad (hopefully)
Post by FredTransit on Jun 22, 2015 9:04:25 GMT 1
Not sure on the paint, will have a look at ours when I am next at the yard.
Post by seaneylad on Jun 22, 2015 9:51:40 GMT 1
Thanks Is there any websites as such that sell mk1 transit parts? I use the likes of burtonpower, fordsmallspares for my escort and pop. or is bet this forum, ebay etc? Cheers
Post by jonochap on Jun 22, 2015 16:55:29 GMT 1
Wow, now that's a project! Good luck e bay, begging, ford transit forum, friends, family, here, e bay, gumtree, here oh and did I say begging???
Post by jonochap on Jun 22, 2015 16:56:59 GMT 1
Also there's a good german site motomobil but that's proper expensive, good for a last resort though and they respond well to e mail
Post by irishtransit on Jun 22, 2015 18:45:00 GMT 1
She looks a nice one.if ya think the a pillars are bad go to page 3 in this section and check out my mk2 amby she has bad pillars.
Post by mrtransit on Jun 23, 2015 6:28:06 GMT 1
Been there, done that! I won't lie to you seanylad, things will get a lot worse looking before they get any better. I have exactly the same ambulance as you, its a Hanlon body for sure. I had rotten pillars, wings,windscreen surround, A panels and steps. Ended up welding on a new cab from below the bottom hinge on the A pillars up. It's a huge job but worth it! What condition is the rest of the transit part in? Chassis, floors, inner wings, spring hangers etc? The best thing to do is get it in a shed, strip it apart so you can make an assement as to how much work it needs. Bear in mind too, that while the rear body is fibreglass and aluminium, it is wood framed. I ended up replacing quite a lot of teak framing due to wet rot! I don't have pictures on me now, but as soon as I get them I'll send them on.
If you Google image search "funbulance" you'll see mine, its on the road 5 years now since its rebuild. But it started out pretty much like yours, so it is possible!
Post by seaneylad on Jun 23, 2015 8:18:56 GMT 1
Been there, done that! I won't lie to you seanylad, things will get a lot worse looking before they get any better. I have exactly the same ambulance as you, its a Hanlon body for sure. I had rotten pillars, wings,windscreen surround, A panels and steps. Ended up welding on a new cab from below the bottom hinge on the A pillars up. It's a huge job but worth it! What condition is the rest of the transit part in? Chassis, floors, inner wings, spring hangers etc? The best thing to do is get it in a shed, strip it apart so you can make an assement as to how much work it needs. Bear in mind too, that while the rear body is fibreglass and aluminium, it is wood framed. I ended up replacing quite a lot of teak framing due to wet rot! I don't have pictures on me now, but as soon as I get them I'll send them on. If you Google image search "funbulance" you'll see mine, its on the road 5 years now since its rebuild. But it started out pretty much like yours, so it is possible! Chassis looks quite solid, havent had any time to even take a look underneath and remove the underseal to see what the floor is like, doesnt look to bad. It is able to be moved and run but engine locked up yday so just trying to free it off so its movable (possibly) aslong as nothing has been damaged in the pinto engine. Yeah the floor in cab is okay(ish) steps are gone though, did you fabricate most of it your self or buy a cab which was in better condition? Is the teak frame expensive, and hard to do? Thanks ill have a good now and take a look
Post by FredTransit on Jun 23, 2015 8:59:00 GMT 1
Wow it's a Hanlon? Our Mk2 is a Hanlon, so I should know better! This is our Lomas, SWB and different windows!
Post by seaneylad on Jun 23, 2015 13:08:07 GMT 1
Wow it's a Hanlon? Our Mk2 is a Hanlon, so I should know better! This is our Lomas, SWB and different windows! Looks cool
Post by seaneylad on Jun 23, 2015 13:08:43 GMT 1
How many of these do you think are left?
what are they currently worth restored? what do you think mines worth in its very current (poor state lol)
Post by FredTransit on Jun 23, 2015 14:03:44 GMT 1
The good news is all Mk1s are on the up. Bad news is ambies are an acquired taste, appealing to less people than say a standard van. It would be a lot of work to return yours to original, it took us about two years to find the right stretchers to replace the lost ones in our Mk2 (she was stripped to become a camper) and another year to find the O2 cabinet. Personally I would say 'restore' yours to a camper.
Post by 81cortina on Jun 23, 2015 17:27:00 GMT 1
i wouldnt mind giving this a go myself. personally its restore outside to an ambulance leave inside as a camper.
