Post by andyb on Jun 25, 2015 22:33:30 GMT 1
Hi I took the old girl out for a long run today, mostly motorway driving. This is the first long run after a lot of work on the engine. It ran very cold for a long while then the temp guage went hot. On the way back the temperature gauge read normal (mid way) then went to hot and coolant boiled bit of steam !!!. However on coming off the motorway within what seemed to be a split second the temp gauge dropped to cold. My gut feeling is this could be a thermostat issue. Any thoughts /advice welcome.
Post by retiredtruckie on Jun 26, 2015 0:02:03 GMT 1
Take the thermostat out do a similar run and compare the results if it runs at a constant temperature then it would be the thermostat
Post by FredTransit on Jun 26, 2015 9:28:12 GMT 1
Almost sounds like a blockage somewhere. Try putting the heater on when the temp goes up, the heater matrix is another little cooling rad. Better you boil than the engine!
Post by dodgerover on Jun 26, 2015 10:18:15 GMT 1
Could it be an airlock that shifted when you came off the motorway? Have you checked the water level since, if it has dropped by a significant amount then that might be the cause.
Post by andyb on Jun 26, 2015 19:41:19 GMT 1
Thanks for the replies all helpful will over the weekend investigate further. Thanks again.
Post by troppo on Jun 26, 2015 23:55:36 GMT 1
Might be worth throwing a can of radiator flush in it at the same time, in case theres a piece of crap floating through the water galleries.
Post by andyb on Jun 30, 2015 23:18:40 GMT 1
I found it did need two pints of water have run it again and gauge remains on cold.. I have not been able to repeat the over heating. I think next I will replace the thermostat and as troppo suggests will flush the system at the same time.
Post by cadill69 on Jul 1, 2015 3:48:58 GMT 1
If it is now not heating up it would suggest the thermostat is now stuck in the open position.
Post by jonochap on Jul 1, 2015 7:42:38 GMT 1
Whenever I've had a question mark over a part I've tried to replace it. It's a lot easier when the next question starts
Post by FredTransit on Jul 1, 2015 13:32:46 GMT 1
I found it did need two pints of water have run it again and gauge remains on cold.. I have not been able to repeat the over heating. I think next I will replace the thermostat and as troppo suggests will flush the system at the same time. Any visible water leaks? Take a close look at the engine on tickover. Look above any wet areas as obv water runs down. Favourites are hoses rubbing, dodgy jubilee clips and splits next to them. Also check your core plugs for rust.
Post by andyb on Jul 2, 2015 20:40:19 GMT 1
Checked for water leaks all ok and flushed the cooling system. Took the thermostat out and tested in boiling water seems to work. Re-filled and took for a drive the temp gauge still reads cold. However on restarting the engine the gauge moves to normal and then drops back to cold. Unfortunately the new stat was the wrong one so still on the look out for a replacement. I think it may just stick so will replace when I can find one also may be worth changing the temp guage sensor perhaps it's just not giving the the right reading.
Post by troppo on Jul 2, 2015 22:38:03 GMT 1
Checked for water leaks all ok and flushed the cooling system. Took the thermostat out and tested in boiling water seems to work. Re-filled and took for a drive the temp gauge still reads cold. However on restarting the engine the gauge moves to normal and then drops back to cold. It always will, the engine is still hot and the water will absorb the heat, but theres no water flowing through the block or radiator to get rid of the heat. Its not unusual for the temp to rise after you turn the engine off.
Post by andyb on Jul 12, 2015 10:13:17 GMT 1
Flushed the system and replaced the thermostat all running fine now so thanks for the advice.
