Post by sleepy on Jul 31, 2015 21:30:03 GMT 1
Not sure if anyone has asked this before. Has anyone fitted a 4 branch sports type exhaust manifold to a pinto mk2 transit. mine also has an MT75 gearbox which is wider than the type 9.
Post by muttleymk2 on Jul 31, 2015 21:50:46 GMT 1
The 4 branch has to be cut and shut to fit the transit, it doesn't go down at the right angle as standard.
Post by sleepy on Aug 1, 2015 6:28:20 GMT 1
The 4 branch has to be cut and shut to fit the transit, it doesn't go down at the right angle as standard. does anyone know which would be the closest ie escort, capri etc the problem I have is my downpipe never seals properly at the manifold I thought I had got a good seal the last time I did it but after 2weeks its leaking again so I thought a 4 branch would overcome this
Post by jonochap on Aug 1, 2015 8:00:06 GMT 1
I have the same problem. As Mutts, the angle of the dangle on car versions takes them through the cab as the down isn't long enough to clear the bottom. They need to be made up but I have only heard of one person who makes them.
Post by sleepy on Aug 1, 2015 8:32:01 GMT 1
I don't mind having a go at extending it a bit as a custom one can be a bit pricey. I had one made up for my pinto in a 100E over 10 years ago and that coat me £280 then
Post by jonochap on Aug 1, 2015 10:35:31 GMT 1
I looked at stainless full system couple of years back and a fellow forum member reckoned about 700 of your earth pounds!
Post by muttleymk2 on Aug 1, 2015 22:49:54 GMT 1
If you get one John, I can modify it for you
Post by jonochap on Aug 1, 2015 23:16:23 GMT 1
...and there's the one person
Post by sleepy on Aug 2, 2015 12:03:29 GMT 1
If you get one John, I can modify it for you I think I might be able to manage it... but if it looks like it's going to be too complicated I will deffo phone you. .. thanks
