Post by dodgerover on Sept 1, 2015 19:47:14 GMT 1
For some reason my indicator warning and high beam warningn lights aren't working, and the alternator isn't charging. All the fuses are ok, does anybody have ideas where I can go chasing earth faults?
Post by muttleymk2 on Sept 1, 2015 22:40:53 GMT 1
Check the plugs in the back of the dash, also the ignition switch.
Post by troppo on Sept 2, 2015 0:14:34 GMT 1
With the alternator check the brushes and make sure all the wires are tight. If its shagged update to a later more powerful unit. With the dash, like muttley said check the plugs and make sure they arent corroded. Check your manual for your earth line and make sure you have clean contacts at both ends
Post by FredTransit on Sept 2, 2015 8:12:07 GMT 1
Also check the actual fuse contacts. A bit of furring up will stop the current.
Post by sleepy on Sept 2, 2015 9:29:14 GMT 1
Qhen my lead that runs from the alternator back to the cab was not connected properly it caused all sorts of problems pn the dash
Post by dodgerover on Sept 5, 2015 18:40:09 GMT 1
Gone through all the connections, MPD supplied a replacement alternator under warranty and now i've got a charging battery and 4 out of 5 idiot lights working. Where can i source bulbs for the instrument panel are they the same as anything modern - the holders are missing too
Post by troppo on Sept 6, 2015 0:07:51 GMT 1
should be able to get them at any car parts place
Post by FredTransit on Sept 6, 2015 11:58:49 GMT 1
Gone through all the connections, MPD supplied a replacement alternator under warranty and now i've got a charging battery and 4 out of 5 idiot lights working. Where can i source bulbs for the instrument panel are they the same as anything modern - the holders are missing too Try ralph for the holder, at least they are easy to post.
