Post by danclift on Dec 16, 2015 17:10:46 GMT 1
Whereabouts on the block is the number ? right side and the numbers are big ish should be easy to see would be somthing like 2?? mine says 205
Post by danclift on Dec 16, 2015 17:12:17 GMT 1
would be like this
Post by PAUL DRIVER 79 on Dec 16, 2015 21:05:31 GMT 1
Thank you
Post by dodgerover on Dec 16, 2015 22:18:14 GMT 1
It would be worth putting the block casting number down on the advert (205 blocks make more money) as well as if its a high or low compression engine, the low compression ones are popular for turboing never seen a turbo d pinto ? They were never factory produced but Janspeed amongst others did kits for them, low compression pistons in transit engine makes them more suitable for running boost, rather than using a decompression plate
Post by PAUL DRIVER 79 on Dec 17, 2015 0:04:55 GMT 1
Yes i thought they d be aftermarket kits,
Someone i know bought a head and janspeed turbo for a mk1 xr2,
couldnt get bits for it though,
