Post by muttleymk2 on Feb 9, 2016 16:37:21 GMT 1
Was just a quick doorstep sill replacement What was left of step and sill Gaffer tape is not a permanent repair it seems Made up a new 1mm step inner sill Fitted outer sill and repaired A and B pillars Now gotta make up new front and rear step outriggers 'cos they gone too
Post by irishtransit on Feb 9, 2016 17:59:19 GMT 1
that rust is a pain in the backside.my little hole in the door turned out to half the inner lip being replaced. I take it there is another sill under the step as I haven't really had a poke around on the bus?
Post by muttleymk2 on Feb 9, 2016 22:17:22 GMT 1
Yeah, the new bit you see is the inner sill that the step fixes too
Post by irishtransit on Feb 10, 2016 0:10:31 GMT 1
okey dokey and does that fix to the outriggers?just trying to get an idea for me.
Post by bullsintransit on Feb 10, 2016 1:29:08 GMT 1
okey dokey and does that fix to the outriggers?just trying to get an idea for me. Check out danclift thread in transit banter"mk2 steps and sills",photos of mine from underneath should show all.
Post by FredTransit on Feb 10, 2016 10:52:28 GMT 1
Camilla!
Post by muttleymk2 on Feb 10, 2016 13:38:06 GMT 1
okey dokey and does that fix to the outriggers?just trying to get an idea for me. Yes it does, if you have outriggers to fix to
Post by irishtransit on Feb 10, 2016 14:15:45 GMT 1
okey dokey and does that fix to the outriggers?just trying to get an idea for me. Yes it does, if you have outriggers to fix to going by the looks of the steps probably not.if I knock up some would 1.2mm metal be ok?that'sif there's chasis to weld to!!!!!
Post by FredTransit on Feb 10, 2016 15:36:02 GMT 1
okey dokey and does that fix to the outriggers?just trying to get an idea for me. Yes it does, if you have outriggers to fix to Yeah alright don't rub it in!
Post by muttleymk2 on Feb 10, 2016 17:07:33 GMT 1
Anything 1mm and up is fine.
Post by FredTransit on Feb 10, 2016 19:35:17 GMT 1
Bah I'm taking that gaffa tape back to the pound shop and give em a piece of my mind.
Post by muttleymk2 on Feb 10, 2016 22:28:23 GMT 1
Well it did last nearly a year!
Post by sidewaysjas on Feb 10, 2016 22:52:32 GMT 1
You turn your back for 5 minutes and rust appears !
Jas
Post by muttleymk2 on Feb 11, 2016 15:38:48 GMT 1
Rear door now, more gaffer tape, what will we find? Rust! Gorn!
Post by irishtransit on Feb 11, 2016 19:32:58 GMT 1
your ploughing thru that one well
