Post by harry on Dec 5, 2016 21:06:32 GMT 1
This is the hydraulic tail lift out of my Mk2 Transit (1986) Pacemaker / 160 - ex community vehicle, hence the lift. The lift worked fine manually with a pipe controlling the lever which pulled up the lift. The lift descended with a twist button. Electric didn't work but might well be the case they weren't connected properly. This will be missing a few nuts and bolts / attachments, and the hydraulic fluid was leaked, so it would need someone who knows they are doing. Am happy to help with loading but obvs need a decent sized vehicle to fit it into. www.ebay.co.uk/itm/332052101314?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649Ebay listing with images. Get in touch if you wanna make an offer.
Post by FredTransit on Dec 5, 2016 21:16:15 GMT 1
Good luck with the sale, I have edited the title as you put the web address for the ebay listing! By the way, if yours is a 160, I have a feeling it's a class4 test. Either way, once you convert to a camper it will be a class4.
Post by harry on Dec 13, 2016 21:17:44 GMT 1
Hi Fred thanks for letting me know, yeah it is a 160. That means I can take it to a 'regular' garage rather than commercial right? Also thanks for changing the title, apologies I didn't mean to put the web address as the title!
Post by FredTransit on Dec 13, 2016 21:25:22 GMT 1
I yours is under 3.5 ton you can get the class4 test. Check your gross on the V5
