Post by harry on Apr 4, 2018 8:51:27 GMT 1
Hi all, Probably gonna be a long shot but I'm in need of a few small bits for my Dormobile. Even if someone could point me in the right direction or an alternative it would be appreciated, I've done some googling and ebaying but with no luck. Sliding window latches. Don't need to the stopper just the sliding bit. ---- Draught excluder for sliding side window. One has one, the other is missing. ---- Rear door lock. This is one has seen better days and the key is long gone Chances are probably slim on the last two at least but worth an ask! Cheers.
Post by FredTransit on Apr 4, 2018 10:06:44 GMT 1
You and me both Harry! The sliding window catches get brittle with age.
Post by harry on Apr 7, 2018 9:30:26 GMT 1
Post by bullsintransit on Apr 7, 2018 10:46:17 GMT 1
Could you modify to fit the sliding windows these catches/handle off of a Mk1/2 side door sliding window ? (Think the handles just held on with pressure,not drilled through glass), same with weather strip on fixed glass,cut a section of frame and rubber to fit over your fixed glass,fix to existing frame, ,stop rattle and draughts
Post by jonochap on Apr 8, 2018 11:03:53 GMT 1
And only £2, this is what they use on the cl...
Post by FredTransit on Apr 8, 2018 12:53:34 GMT 1
Exactly that. Well spotted Jonno!
Post by muttleymk2 on Apr 8, 2018 21:27:20 GMT 1
Easy Fred, he will be expecting stripes
Post by FredTransit on Apr 9, 2018 14:26:33 GMT 1
Are you getting bored with being the world's most underworked mod then Muttley?
Post by jonochap on Apr 9, 2018 14:45:44 GMT 1
Easy Fred, he will be expecting stripes Somebody say stripes?? 😁🛠⚜️🔩🎖🏅
Post by muttleymk2 on Apr 9, 2018 21:06:21 GMT 1
See what I mean
Post by harry on Apr 12, 2018 10:28:35 GMT 1
Cheers all.
I got some latches for the sliding door windows reckon they will be easily modified.
Def check out those things as well Jono.
Whats the thoughts on the rear door lock jobby?
Also what are the chances of anyone having original dormobile wing mirrors? Slim to none I'd guess! Stupid me managed to break mine trying to take it apart.
Post by FredTransit on Apr 12, 2018 13:47:17 GMT 1
I use a generic head from a commercial motor factors. They look the part and are £10 each, they also do a generic arm which looks fine. I have a new one in the van, will have a look and let you know who makes them.
