Post by landieman on Apr 10, 2018 23:35:30 GMT 1
Good Evening All,
Our inner wings on our 1985 Dormobile bus are crumbling before our very eyes! They need to be removed and replaced. Does anyone know of a set available for sale?
Many Thanks,
Harry
Post by FredTransit on Apr 11, 2018 9:50:28 GMT 1
Welcome to the forum! Inner wings are hard to find. Is it the bit round the bonnet hinges or worse? Could they be repaired? For new panels you could try Ralph on here but inner wings are rare.
Post by landieman on Apr 11, 2018 9:57:11 GMT 1
Rugby ball sized holes on each side. The hinges have broken off
Post by FredTransit on Apr 12, 2018 8:17:05 GMT 1
They can be repaired. It depends if you are going for 'restoration' or 'sound repair'.
Post by harry on Apr 12, 2018 10:25:06 GMT 1
Got the same bus. Ours were in bad shape too (although not that bad). I think they modified the bonnet on the dormobiles because on mine water leaks past the gutter down the inner wings and ends up on the chassis underneath the steering column ! Anyway might be a welding job. I haven't even looked at the other side (im talking about inside the engine bay). Its covered it underseal and doesn't do anything when I poke it with a screwdriver so I'm leaving it for a year or two until I have time to properly sort it.
Post by FredTransit on Apr 12, 2018 13:49:07 GMT 1
The Dormobile bonnet is different to the ordinary standard bonnet. It's cut off at the back to allow for the screen surround.
Post by muttleymk2 on Apr 12, 2018 21:09:55 GMT 1
I have repaired some pretty awful inner wings
Post by jonochap on Apr 12, 2018 21:51:17 GMT 1
I have repaired some pretty awful inner wings (I did already tell him about you) 😁
Post by landieman on Apr 13, 2018 6:41:58 GMT 1
If you think they can be welded then maybe we can go down that route as they really are bad! Huge holes either side lol. As for the bonnet, I guess we are going to have to cut ours down then.
Thanks for everything so far guys. It’s a big help
Post by FredTransit on Apr 13, 2018 10:11:24 GMT 1
Have you got a spare bonnet then? The standard bonnet has a slight flip up on the back corners.
Post by landieman on Apr 13, 2018 13:11:03 GMT 1
Just bought one. May be able to get a dormobile one
Post by FredTransit on Apr 13, 2018 15:59:24 GMT 1
If you don't need it, try to get the right one. Yours didn't look too bad, that's pics for you though.
Post by landieman on Apr 15, 2018 18:41:58 GMT 1
If you don't need it, try to get the right one. Yours didn't look too bad, that's pics for you though. It’s creased from where a tractor reversed into it in storage. It’s sort of folded it inwards and torn the hinge off the opposite inner wing, ripping quite a chunk of inner wing out with it.
Post by FredTransit on Apr 16, 2018 10:43:19 GMT 1
To be honest, hit it with a very big hammer until it's mostly the right shape. Then prime, smooth with filler and paint. You have nothing to lose. If it doesn't work, buy another one.
Post by landieman on May 3, 2018 3:11:07 GMT 1
To be honest, hit it with a very big hammer until it's mostly the right shape. Then prime, smooth with filler and paint. You have nothing to lose. If it doesn't work, buy another one. I like your thinking!
