Post by wobbers on Sept 14, 2018 8:44:04 GMT 1
I've recently discovered the leisure battery in my camper is getting no charge whatsoever. Not from the main battery or when plugged in. At some point somebody has done some diy electrics and not to a very high standard either. Ive been advised to get a split charger by a friendly auto electrician and he will re do my electrics for me.
I'm not sure what I should be looking for as there seem to be plenty of options. What are other people using?
Post by FredTransit on Sept 14, 2018 10:29:45 GMT 1
Ah the old camper and dodgy DIY electrics problem. Electrikery isn't my strong point, I would ask Muttley!
Post by muttleymk2 on Sept 14, 2018 22:17:42 GMT 1
You need a voltage sensing split charge relay
Post by sleepy on Sept 15, 2018 8:50:23 GMT 1
don't bother with the cheap ones I use the durite one and it's given me no problems
Post by bullsintransit on Sept 15, 2018 12:37:58 GMT 1
X2 on Sleepy has said, the durite is also that simple to wire up that you may not need to use an autoelectrician to install, the extra money for durite compared to cheaper alternative potentially saving instalation labour bills.
Post by sleepy on Sept 15, 2018 15:00:04 GMT 1
so easy to wire up
