Post by stoney on Jan 7, 2013 21:15:00 GMT 1
Hi all
Anyone interested in a mk1/2 (or even 3 but shhh) tipper/recovery body?
spec is
13ft long 6ft wide ish made from thick steel box section with a steel floor 8 welded in tie down points winch mountings (with steel surround so it cant get nicked) 10ft ish ally dropsides but no back tipping gear (ram leaks if pushed to far but chome is perfect) bar across the back for ramps to hook onto
bed is solid but dented and needs paint, and tipping chassis will need a little tlc where hiab mount was cut off.
This body has worked hard for me and even harder for its previous owner, its taken some serious loads, Ive had about 3 ton on it and it still tipped fine.
Its already removed and ready to go.
The price depends on what you want ie.
Bed on its own £75 bed with tipping chassis and gear £120 bed with tipping chassis/gear and dropsides £150
I hope someone wants it, its very well made and would be a shame to cut it up for the box section and weigh the rest it (which is what will happen if it doesn't sell)
Post by stoney on Jan 7, 2013 21:25:54 GMT 1
forgot to say it overhangs the rear of the chassis by about 3ft which means when you tip it as the front goes up the rear comes down, Ive loaded some low cars onto this using a set of 7 1/2ft ramps and it works surprisingly well.
