Post by samps on Mar 10, 2019 18:15:51 GMT 1
Hi. I was hoping you could help identify the age of my van. The only ID on the van, is the following.
Plate in the engine bay upper right on the fire wall. D/LLAMBASS CDO 9322
On the bell housing behind the starter. 2400E 7505G the last letter maybe a C With the letter C centred below.
On the gearbox below the gear stick. AGA 2 Below this is. 2810E - 7222 - B Below this is the FoMoCo stamp.
Any feed back would be appreciated.
Regards Nigel.
Post by FredTransit on Mar 10, 2019 18:42:51 GMT 1
I see from your first post this is an early Mk1. What's the history of the van? Did you get a UK registration number with it? Any paperwork? The Mk1 came out in 1965, so if you think it's a 1967, it was most likely to have been manufactured in 1966.
Post by samps on Mar 10, 2019 19:00:44 GMT 1
Hi Fred. I have looked more closely. The last 7 letters and numbers on the bulk head read GDO 9322
I am thinking this is March 1967 looking at the vin decoder. I found after posting todays earlier post.
I have no paper work or reg number.
Post by FredTransit on Mar 10, 2019 20:12:33 GMT 1
Do you have a VIN number? Is that what you say is on the plate? You can get an HPI check on a VIN number, it often gives a reg number. You can then put the reg into the DVLA website and see when the van was registered.
Post by samps on Mar 10, 2019 20:59:43 GMT 1
Thanks. I will give this a try.
