Post by jonochap on Nov 1, 2012 12:21:44 GMT 1
Hi loverly people in my compooter...does anyone have a mk 1 windsreen by any chance???
Post by FredTransit on Nov 1, 2012 14:52:10 GMT 1
Muttley's got one! Debster yours is a parcel vsn screen and won't fit a standard van.
Post by gpw on Nov 1, 2012 15:35:40 GMT 1
Have you lost interest in sorting your brakes please Jono only I've got a couple of contacts hanging on to quote you on parts?
Post by jonochap on Nov 1, 2012 17:42:15 GMT 1
Ah GPW, not at all, thank you for the offer of suppliers for parts but found a whole unit on e bay as recomended by my very competent mechanic friend, I am still in awe of your knowledge, paying close attention and listening very carefully. Last night was a 6th form halloween party for my daughter and as its half term this week has been being dads cab and working. Then losing the windscreen today has put alot on hold...will get the vin number and will post photos of making the old unit good so your advice and help will still be greatly appreciated : )
Post by jonochap on Nov 1, 2012 17:43:14 GMT 1
And I'm not sure that the replacement wont need parts so ignore that comment...the saving of the servo unit will be the work for this weekend : )
Post by jonochap on Nov 1, 2012 17:43:41 GMT 1
And thanks Fred, will contact the Mutts
Post by gpw on Nov 1, 2012 17:44:24 GMT 1
Thanks Jono.
Post by FredTransit on Nov 1, 2012 22:52:33 GMT 1
Mutts having trouble getting on the forum but I am sure he'll be along shortly!
Post by jonochap on Nov 2, 2012 0:30:37 GMT 1
Have had a message from mutts so all good...lots to get organised now
Post by gpw on Nov 2, 2012 9:08:03 GMT 1
And I'm not sure that the replacement wont need parts so ignore that comment...the saving of the servo unit will be the work for this weekend : ) Please can we sort out whar's called what Jono? Where I come from, 1) the servo is the black pressed steel thing that rings when you hit it, it's held on to your bulkhead by nuts inside your cab. 2) the reservoir is the white, semi-transparent plastic container that holds brake juice. 3) the master cylinder is the cast iron thingy underneath the reservoir, it's held on to the servo by a couple of nuts, the reservoir plugs into it. one or more brake pipes come out of it.
Post by jonochap on Nov 2, 2012 9:21:46 GMT 1
My bad thanks, will reply on the other thread
