Post by corktina on Mar 23, 2014 16:40:57 GMT 1
This is how Duck looked on my recent round Ireland trip....a bit scruffy near the waterline..... well, I started work on him today...expect more photos as I go along. Most of what you can see in that pics is due to someone painting over the rust, so I've started stripping it back, nothing alarming so far...watch this space....
Post by muttleymk2 on Mar 23, 2014 20:00:29 GMT 1
Good luck, hope there's not too many surprises
Post by corktina on Mar 23, 2014 21:37:55 GMT 1
I'm not expecting any.. she's rock solid underneath the Tester and my Mechanic both told me the only rust is the bits you can see on the outside. Now it's an Old Ford, so there may well be some underneath.... (just approaching 70000 miles now
Post by irishtransit on Mar 23, 2014 23:22:52 GMT 1
go luck with the work.
Post by FredTransit on Mar 24, 2014 10:37:36 GMT 1
good luck mate. If only rust was worth money eh?
Post by corktina on Mar 25, 2014 22:51:10 GMT 1
too right....work went well today....but how is it the lower valance now looks like it's full of filler? can't be as you know, but it LOOKS like it is!
Post by corktina on Mar 26, 2014 12:18:07 GMT 1
This where I got too...I have too much hi-build primer I the panel gaps, so there's a lot more sanding going to take place yet. Always takes me ages to get it to look somewhere right....then I have to match the paint somehow! You can see from the first pic that the panel gaps had already been messed around with before I started.
Post by corktina on Mar 26, 2014 14:24:39 GMT 1
Looks a bit better...needs a bit more yet though (that's still primer Phot looks worse than it actually is and some FORD stripes should hide the worst of it :-)
Post by corktina on Mar 26, 2014 14:26:57 GMT 1
This is the bit behind the wheel. There was a small hole there but as it is double skinned, I just treated it and filled it...have to shape it a bit more yet
Post by irishtransit on Mar 26, 2014 15:05:35 GMT 1
she'll look tidy enough when she's done.
Post by corktina on Mar 26, 2014 15:32:21 GMT 1
yep very small stuff really. This is the top of the drivers wing with a little removed to have a look-see...probably th owrst bit on the whole van. I' might have to weld a bit in here by the looks. The rest of the wing is sound except a similar scab just above the headlight. Someone had plastered something over the rust by the looks
Post by corktina on Mar 26, 2014 16:10:16 GMT 1
if only they had touched it up properly
Post by irishtransit on Mar 26, 2014 17:14:53 GMT 1
shouldn't be too much trouble to cut a piece and weld in there as long as ya careful with the heat.
Post by corktina on Mar 26, 2014 17:47:26 GMT 1
Yep, it's a bit visible so I'll have to try really hard...
Post by corktina on Mar 27, 2014 12:47:35 GMT 1
Ignore the paint runs, has to be rubbed back yet...improving slightly I've decided to get my wing done professionally so I'm just doing a temporary job on it fttb..(duct tape...(not really) should be Duck tape I guess
