Post by irishtransit on Jul 18, 2014 17:38:19 GMT 1
Having never worked on a transit before i thought i'd get some advice.the rear corner panels need work,around the light clusters,at the bottom and at the top.noe i have replacement panels but eas wondering id it best to remove and teplace the whole panels or just cut out the rot and repair the existing ones.
Post by muttleymk2 on Jul 18, 2014 21:58:35 GMT 1
Cut it all out but leave enough to weld to
Post by sidewaysjas on Jul 18, 2014 22:22:42 GMT 1
I'd agree, cut out the old panel and replace with new! It will last much longer.
Jas
Post by troppo on Aug 11, 2014 1:28:37 GMT 1
Personally i`d cut the rust out plus an extra inch or two, the smaller the replacement you put in the easier it is to keep positioned right and theres less welding putting less heat into the panel which means less warping
Post by irishtransit on Aug 11, 2014 21:58:19 GMT 1
Personally i`d cut the rust out plus an extra inch or two, the smaller the replacement you put in the easier it is to keep positioned right and theres less welding putting less heat into the panel which means less warping checked out one of the panels and the bottom too is rusty so will only cut out the rusty bits.the weather is shite here so nowt happening at the moment. one other question where the panels join there is a seam between them,how do people weld 2 panels together but leave the gap in place?
Post by muttleymk2 on Aug 11, 2014 22:24:26 GMT 1
Run a good bead of weld at the joint, then run the grinder down the seam line to match the original
Post by troppo on Aug 12, 2014 6:36:39 GMT 1
If you can separate the seam plug weld the two pieces together. Failing that (making sure to use the same gauge steel) fold the two sides of the seam, plug weld them together and use that to patch the rust
Post by irishtransit on Aug 12, 2014 13:35:39 GMT 1
cheers for the advice.
Post by troppo on Aug 13, 2014 3:44:21 GMT 1
No worries, one thing i forgot to mention, if you can avoid it do not make any sharp angular corners if you can avoid it. They will concentrate heat and cause warpage unless you are very careful and very lucky, try to make rounded corners if you can (its not always possible but do it where you can
Post by irishtransit on Aug 13, 2014 13:32:12 GMT 1
cheers again.one day i'll start.
