Post by RDTranny on Sept 27, 2014 23:16:52 GMT 1
Great work going on there. Good to see you're taking her on. Best of luck!
Post by irishtransit on Sept 28, 2014 19:12:58 GMT 1
well been out at the old girl this weekend and been quite stressful.been having wifey troubles and I think it transferred to the work I was trying to do.main problem was the welds just not taking regardless of clean metal,good earth etc. but soldiered on and got the door on but had to remove the door seal as it was getting in the way.still got to join the bottom sections of the pillar together but getting there oh and eventually managed to get some good welds in the end.
Post by munsterboy on Sept 28, 2014 21:17:48 GMT 1
Well done, glad to see it shaping up
Post by irishtransit on Sept 28, 2014 23:10:15 GMT 1
Cheers.will be a long project.
Post by muttleymk2 on Sept 28, 2014 23:22:08 GMT 1
Tis a grand job that you are doing
Post by troppo on Sept 29, 2014 4:37:52 GMT 1
goingg well mate, one thing that can effect a welder is if your running it on an extension lead. You drop a lot of current that way and your welder wont have any grunt
Post by jonochap on Sept 29, 2014 7:36:01 GMT 1
Sorry to hear the tough times IT, hope it all settles down
Post by corktina on Sept 29, 2014 9:13:20 GMT 1
The painted area looks just fine...keep going
Post by irishtransit on Sept 29, 2014 13:27:06 GMT 1
cheers guys.still a fair bit to do at the bottom.one problem I have encountered is there isn't enough room to plug weld the corner to the side panel.originally it was spot welded in place.
Post by troppo on Sept 30, 2014 2:53:52 GMT 1
cheers guys.still a fair bit to do at the bottom.one problem I have encountered is there isn't enough room to plug weld the corner to the side panel.originally it was spot welded in place. Welcome to the wonderful world of rust repairs lol
Post by irishtransit on Sept 30, 2014 13:31:15 GMT 1
cheers guys.still a fair bit to do at the bottom.one problem I have encountered is there isn't enough room to plug weld the corner to the side panel.originally it was spot welded in place. Welcome to the wonderful world of rust repairs lol not a total virgin as I have a 90% completed Cortina locked up in the other garage.
Post by troppo on Sept 30, 2014 13:51:42 GMT 1
OK so i`m preaching to the choir lol, your doing great so far you`ll knock this one out easy
Post by irishtransit on Sept 30, 2014 15:36:00 GMT 1
you're sorta right as this is the very first time I've worked on a transit and it is a shock how they rust.any advice is always welcome.
Post by rustwidow on Sept 30, 2014 18:52:27 GMT 1
It's the sheer size of them that's scary, panels are bigger than on a car lol
Post by muttleymk2 on Sept 30, 2014 20:04:22 GMT 1
you're sorta right as this is the very first time I've worked on a transit and it is a shock how they rust.any advice is always welcome. Yeah but you buy all the really rusty ones John
