Post by corktina on Jul 21, 2015 20:27:05 GMT 1
very close now. Just have to fabricate a clip to replace the one I've lost that secures the choke cable, fit the bumper etc an dsort ut the brakes
Post by jonochap on Jul 21, 2015 22:38:59 GMT 1
Brakes might just need a bit of tlc, fingers crossed...
Post by cadill69 on Jul 22, 2015 2:06:44 GMT 1
Have you connected the vacuum tube to the brake servo?
Post by corktina on Jul 22, 2015 8:48:57 GMT 1
yes...the brakes don't "pump up" so I'm thinking master cylinder seala. It isn't losing fluid as far as I can see .
I'm a bit worried though. It cut out last night and I assumed it ran out of petrol but at the time I was investigating a rubbing noise and slight knock. Ithought it might be the timing belt cover but now I'm worried it may be more sinister
Post by corktina on Jul 22, 2015 13:57:51 GMT 1
engine running fine, no brakes still last lap now (except doing the brakes
Post by corktina on Jul 22, 2015 15:45:51 GMT 1
all done bar the brakes now
Post by corktina on Jul 22, 2015 16:37:34 GMT 1
it starts fone and runs Ok for afew minutes and then cuts put and wont restart for half an hour or so.......weak petrol pump perhaps? scratching my head now
Post by troppo on Jul 23, 2015 6:39:40 GMT 1
Might need to check your floats, sounds like its flooding for some reason
at last!
Jul 23, 2015 6:43:36 GMT 1
via mobile
Post by retiredtruckie on Jul 23, 2015 6:43:36 GMT 1
If it has one check the ballast resistor too but could be what troppo said
Post by corktina on Jul 23, 2015 8:08:07 GMT 1
that's the trouble always...could be any one of a dozen things....I'm going to clean up all the connections to start with....I can't think the coil would overheat in a minute, but could have become faulty during the lay off period...but so could a few things! I'll have the top off the cerb to check the choke isn't sticking too I think
at last!
Jul 23, 2015 12:15:49 GMT 1
via mobile
Post by FredTransit on Jul 23, 2015 12:15:49 GMT 1
Check the cheapest first! Gunge in the carb, fuel pump diaphragm, sticking carb float. Leccy ignition doesn't have much to go wrong.
Post by corktina on Jul 23, 2015 17:30:32 GMT 1
I've sorted the running problem....not sure how, just clenaed and checked everything
Brakes still not working. Borrowed a pressure bleeder and still no joy. I took one pipe off the master and pumped pedal...first pump lots of fluid , after wards just air which was sucking in and out with the pedal, so I reckom my first thought of the Master being duff was right. what do you think? I'll have to try and get a kit for it I think
Post by corktina on Jul 29, 2015 16:49:26 GMT 1
master cylinder sourced from the UK fitted and working. :-) Been on a test drive to the commercial mechanic who loaned me the pressure bleeder (and wouldn't take money for the fluid I used :-) tomorrow morning is tinkering time and then the road trip I promised a while back...sort of Buttevant direction
at last!
Jul 29, 2015 18:25:23 GMT 1
via mobile
Post by FredTransit on Jul 29, 2015 18:25:23 GMT 1
I hope the fluid didn't go to the servo. At least they are working, good news.
Post by corktina on Jul 29, 2015 18:52:58 GMT 1
i haven't looked but I wasn't losing any and there were no clouds of smoke which I;d expect if that happened.Servo is working
if it makes sesne, we reckon that the inner piston was seizd and the outer one (nearest the servo) was working, pushing the fluid back inot the reservoir
