at last!
Aug 5, 2015 12:11:15 GMT 1
via mobile
Post by retiredtruckie on Aug 5, 2015 12:11:15 GMT 1
You'll get it on the next round
Post by corktina on Aug 5, 2015 16:04:44 GMT 1
I think so it failed on
sticky caliper front offside (freed off this morning) suspect wheel bearing front offside ( was a little loose so I tightened it a little and hope that's solved) rear brake imbalance...going to get a local mechanic to do that for me as I have no way of knowing how much to adjust it(may well just need more bleeding, handbrake is perfect) Loose bolt, centre prop mounting (my fault for not tightening it enough)
That's it....not too bad is it?
Post by jonochap on Aug 5, 2015 18:00:24 GMT 1
Wheel calliper should be ok, Can you bite the bullet and Replace the wheel bearings? Time will tell on the rears Should be ok, doesn't sound like much if your assumptions are right
Post by irishtransit on Aug 5, 2015 18:37:56 GMT 1
shame to hear that but could be a lot worse I suppose.
Post by corktina on Aug 5, 2015 19:14:42 GMT 1
I didnt expect to pass really. It failed by very little....
Post by jonochap on Aug 5, 2015 21:39:36 GMT 1
Certainly close and good news!
Post by troppo on Aug 5, 2015 22:43:34 GMT 1
well it only failed on minor things, nothing thats going to break the bank to repair
Post by corktina on Aug 7, 2015 12:33:33 GMT 1
Duck is all mended and ready for the retest next Wednesday. I hope I freed off the calliper enough and that the wheel bearing isn't in need of replacing. My mechanic thinks it should be OK the way I did it. If it passes I'll be taxing it and heading for the ferry!
Post by retiredtruckie on Aug 7, 2015 12:44:04 GMT 1
Good luck hope all goes well
Post by corktina on Aug 8, 2015 12:44:50 GMT 1
ready for the road trip...just needs a ticket and a tax disc...roll on Wednesday!
Post by jonochap on Aug 8, 2015 20:30:23 GMT 1
And what is the road trip itinerary?
Post by corktina on Aug 8, 2015 20:40:01 GMT 1
Steam Railways of the UK.
Probably Welsh Highland/Festiniog/Llangollen/Severn Valley/Glos Warks/Quainton/Didcot/Mid hants/ Swanage/
Post by jonochap on Aug 8, 2015 23:29:21 GMT 1
Aw Swanage, say hi to Enid for me great train ride!
Post by corktina on Aug 9, 2015 7:30:30 GMT 1
No idea who Enid is but I'm a Life member there, so hoping to get that far.
Post by irishtransit on Aug 9, 2015 15:13:31 GMT 1
lucky you to be able to do it.fingers crossed for Wednesday.
