Post by jonochap on Jun 17, 2018 22:32:53 GMT 1
Careful with the nib and bolts on the (water pump?) pulley 😊 I ended up grinding the nib off and fitting flat head bolts but your engine mounts might not be as springy as puks.
Post by rick on Jun 17, 2018 23:27:48 GMT 1
I've thought of that one mate my plan is to put a later water pump on and may be trim the bolt heads back a touch as u say but it might not be on this engine unfortunately I'm guessing that will give about another 10mm clearance on the rad
Post by jonochap on Jun 18, 2018 17:54:36 GMT 1
I would have thought it will get you in line with the alternator front 😊
Post by rick on Jul 6, 2018 23:02:46 GMT 1
Engine out engine in gone to the original engine I was going to use the other was smoking to much for my liking 😕 Anyway he's now moted and I've also fitted a cam belt and water pump kit it's running great I've done about 30 miles as a test run only slight gripe is I feel it's lacking top end which I think is a lack of fuel so I'm going to look at the carb when I get chance.
Post by rick on Jul 6, 2018 23:05:52 GMT 1
Also fitted one of the cheapo head units everyone seems to be fitting it works a treat for 13 quid 😊
Post by rick on Jul 15, 2018 21:47:30 GMT 1
70 mile round trip today to a gala so far so good ☺
