Post by FredTransit on Jun 24, 2015 9:28:23 GMT 1
The quickest way to go disc on a Mk1 is to use the Mk2 axle. That way you only need the U bolts and flexi hoses. You could do the hubs too, but it depends how easy the hub assembly comes apart.
Post by rick on Jun 24, 2015 12:37:36 GMT 1
It's got solid discs on it now but it's been sat 25 years so do need replacing I've see the thread about LDV calipers fitting straight on so that could be an option maybe
Post by rick on Jun 27, 2015 22:54:14 GMT 1
I never thought I'd see the day I was tidying up transit wheels up What pressure do I need in the fronts and rears? and I've got 195 r14 all round is that right?
Post by dodgerover on Jun 27, 2015 23:02:26 GMT 1
I've got 50ish psi in the fronts 40 psi in the rears
Post by FredTransit on Jun 28, 2015 10:46:24 GMT 1
I would do it the other way round DR. 45 on the front and 50 on the back
Post by dodgerover on Jun 28, 2015 11:18:00 GMT 1
I tend to keep the front ones hard to help with parking as I notice when they have lost 5 psi or so as the steering gets a bit harder, it doesn't wander about on the road though at the speeds i travel.
Post by rick on Jun 28, 2015 19:06:02 GMT 1
Cheers both I was thinking it would need to be more in the rears with it being a camper I take it the tyres are good as 195's?
What sort of speed should the old girl be happy at? Will it plod at 50?
Post by rick on Jun 30, 2015 12:26:26 GMT 1
^^^^^^^ anyone?^^^^^^^^
Post by retiredtruckie on Jun 30, 2015 12:48:46 GMT 1
I don't see 50 being to much to ask but would personally run 45psi all round
Post by dodgerover on Jun 30, 2015 17:22:44 GMT 1
Cheers both I was thinking it would need to be more in the rears with it being a camper I take it the tyres are good as 195's? What sort of speed should the old girl be happy at? Will it plod at 50? Depending on what axle ratio its running and what engine/ gearbox, my mk2 has the 2.0 low compression pinto, original 4 speed and 4.63 axle ratio and will happily run at 50, 60 is ok but it starts to feel like you are pushing it a bit.
Post by jonochap on Jun 30, 2015 17:24:21 GMT 1
Not sure it's a plod at 50 it may take a while to get there and plan for inclines
Post by rick on Jul 1, 2015 12:32:45 GMT 1
I'll stick with 50psi all round and see how I get on It's got the 2l v4 in it and a 4 speed box no idea of ratios etc I'll be happy enough if it will do 50 I don't want to drive it like a race car but then again anything under 50 on a motorway etc is a bit slow imo. I haven't tried to start it yet or even turn the engine over so I still dont know if it's evengoing to run
Post by jonochap on Jul 1, 2015 19:40:21 GMT 1
I have every finger and toe crossed you might find 50 like pram wheels
Post by rick on Jul 12, 2015 22:25:54 GMT 1
Post by irishtransit on Jul 12, 2015 23:06:49 GMT 1
Nice work.
