Post by danclift on Jan 27, 2016 10:37:50 GMT 1
Post by FredTransit on Jan 27, 2016 10:49:15 GMT 1
More steady progress. Keep it up!
Post by danclift on Jan 27, 2016 12:17:01 GMT 1
More steady progress. Keep it up! i cant its raining just spent 2 days watching tv now waiting for rain to stop to do bit more
Post by FredTransit on Jan 27, 2016 12:39:21 GMT 1
That's the thing about vans, you need a big place to get them under cover.
Post by Ralph on Jan 27, 2016 14:36:45 GMT 1
The bottom of the B post should be curved round to meet the inner sill, like this. It might be why your door's not fitting.
Post by danclift on Jan 27, 2016 15:53:57 GMT 1
the door is not hitting the sill tho the problem is its rubbing on the wing and the lines on the door dont line up with the body lines
Post by danclift on Jan 28, 2016 18:08:06 GMT 1
Post by danclift on Feb 4, 2016 17:28:34 GMT 1
Post by sleepy on Feb 4, 2016 17:50:31 GMT 1
Looking good mate
Post by Ralph on Feb 4, 2016 18:08:51 GMT 1
Expanding foam is not a good idea it absorbs water & will rot it from the inside out. Also its a major fire risk if your welding close by.
Post by dodgerover on Feb 4, 2016 18:16:05 GMT 1
Please tell me that's not expanding foam? You've gone to loads of trouble putting metal in - why make sure it rots out again?
Post by sleepy on Feb 4, 2016 18:32:47 GMT 1
Oh dear... on my phone it looked like a rag until you guys pointed it out
Post by pk on Feb 4, 2016 18:35:10 GMT 1
We had a similar problem with the stock cars, we used to foam the bulkhead and fuel tanks with fire retardant foam but within a year the surrounding metal would all bubble up. The foam seems to entrap moisture within the small cavities and make things worse. I'm using good old waxoil and under seal.
Post by danclift on Feb 4, 2016 18:37:27 GMT 1
its expanding foam i painted as much as i could inside then filled with foam. my dad had a few of these vans and done sills a few times but the last time he put foam in and then it never needed doing again after that
Post by dodgerover on Feb 4, 2016 18:55:59 GMT 1
It's a right bad idea. Waxoil and old engine oil is as good as anything blast it in with a long probe on the end of a Shultz gun.
