Hello
Feb 14, 2016 6:55:59 GMT 1
Post by 78transitsundowner on Feb 14, 2016 6:55:59 GMT 1
Should be fairly rust free then. I run a sports filter on my 250. Is fairly rust free, I have a sports filter but firewall wont let it fit on. What sort do you have fitted and do you know where I can get one?
Hello
Feb 14, 2016 7:03:11 GMT 1
Post by cadill69 on Feb 14, 2016 7:03:11 GMT 1
Mine is a Mk1 pre cross flow with LPG so a bit different. Give J & B autos @ Dandenong Vic a call. 0397925000. They post. Conrods sundowner
Hello
Feb 14, 2016 9:02:16 GMT 1
Post by 78transitsundowner on Feb 14, 2016 9:02:16 GMT 1
Mine is a Mk1 pre cross flow with LPG so a bit different. Give J & B autos @ Dandenong Vic a call. 0397925000. They post. Conrods sundowner Awseome thanks for the heads up
Hello
Feb 14, 2016 10:55:13 GMT 1
Post by conrod on Feb 14, 2016 10:55:13 GMT 1
well done, another Sundowner saved Are you going to leave it green, or restore back to original Fireglow orange? Little bit difficult fitting an airfilter on these as you know. If you want original then any Australian 4.1 Mk2 Transit has the same air filter setup you need. Basically it is a modified XC/XD Falcon setup.
Hello
Feb 15, 2016 7:58:54 GMT 1
Post by 78transitsundowner on Feb 15, 2016 7:58:54 GMT 1
well done, another Sundowner saved Are you going to leave it green, or restore back to original Fireglow orange? Little bit difficult fitting an airfilter on these as you know. If you want original then any Australian 4.1 Mk2 Transit has the same air filter setup you need. Basically it is a modified XC/XD Falcon setup. Gday and thanks. The plan is to drive for now (once roadworthy and registered) but at some point in the future I definitely want to go back to the stock colour. I have another air filter I just need the 57mm flexible pipe to make it work I think. For now anyway. Have a great day.
Hello
Feb 16, 2016 14:04:53 GMT 1
Post by cadill69 on Feb 16, 2016 14:04:53 GMT 1
Hi, I just inspected a transit I found on Gumtree. It was suppose to be a Mk1 but It turned out to be a Mk2 and even tho it is crap it looks mechanically ok and it has the stock rubber and air filter you are after. If you want to pick up lots of spares ie brake booster, steering box, wipers, windscreen head lights etc etc you will probably get the whole van for next to nothing or strip it. Your call. Its 1979. Here is the link: www.gumtree.com.au/s-ad/sydney-city/cars-vans-utes/1970-ford-transit-van-minivan/1104202678
Hello
Feb 17, 2016 7:32:38 GMT 1
Post by 78transitsundowner on Feb 17, 2016 7:32:38 GMT 1
Hi, I just inspected a transit I found on Gumtree. It was suppose to be a Mk1 but It turned out to be a Mk2 and even tho it is crap it looks mechanically ok and it has the stock rubber and air filter you are after. If you want to pick up lots of spares ie brake booster, steering box, wipers, windscreen head lights etc etc you will probably get the whole van for next to nothing or strip it. Your call. Its 1979. Here is the link: www.gumtree.com.au/s-ad/sydney-city/cars-vans-utes/1970-ford-transit-van-minivan/1104202678 Thanks heaps for the heads up. I am checking it out now.
Hello
Feb 18, 2016 13:30:34 GMT 1
Post by 78transitsundowner on Feb 18, 2016 13:30:34 GMT 1
Mine is a Mk1 pre cross flow with LPG so a bit different. Give J & B autos @ Dandenong Vic a call. 0397925000. They post. Conrods sundowner Unfortunately J & B autos @ Dandenong Vic have changed hands and no longer have this sort of stuff. So I am back to trawling the old interwebs.
Hello
Feb 18, 2016 13:54:25 GMT 1
Post by cadill69 on Feb 18, 2016 13:54:25 GMT 1
Wonder what they did with their stock? Joe used to run it and then his son recently took over. Here is Joe's mobile 0427792003
Hello
Mar 1, 2016 13:38:39 GMT 1
Post by 78transitsundowner on Mar 1, 2016 13:38:39 GMT 1
Wonder what they did with their stock? Joe used to run it and then his son recently took over. Here is Joe's mobile 0427792003 Cheers champ much appreciated =)
Hello
Mar 2, 2016 5:20:50 GMT 1
Post by martinp on Mar 2, 2016 5:20:50 GMT 1
I've got one from the mark 1 ford six. It's a bit rough but should do the trick if it is the same. Only trouble is the filters are hard to come by..
