Post by alexjohanssonswe on Jun 9, 2016 0:38:45 GMT 1
Ooh, thats Sounds bad! Normaly i use to put 20/50 in older worn engines without problems. But ill put 10/30 in it instead.. Wonder what The oil pressure gauge is going read, im down on 1bar on idle when its warm. (+20-25c)
Post by bullsintransit on Jun 9, 2016 1:12:43 GMT 1
One thing I have noticed in both the 'motomobil' and also in 'Swedwspeed' parts/tuning for the colongev4 is that they both offer higher volume oil pumps/cooler kits,just makes me wonder if the original pumps ok with thinner oil but struggle with thicker.This is just a observation,but why offer upgraded parts if the original was satisfactory? Know from reading Ford manual that the oilways were redisigned for better flow in post fall 67 onwards,different heads etc,but maybe it's an inherent problem with the engine.
Post by alexjohanssonswe on Jun 9, 2016 23:27:17 GMT 1
Sounds like something that i should put on The "to buy" list when fixing The engine! How is it one know if The car runs a cologne engine or an essex egine? Something with the location of The distributor right?
Post by bullsintransit on Jun 10, 2016 0:09:27 GMT 1
Yes,on an Essex the distributor is at front of engine,on colonge at rear next to bulkhead
Post by rick on Jun 10, 2016 7:47:59 GMT 1
Post by alexjohanssonswe on Jun 12, 2016 19:55:15 GMT 1
Anybody has a picture of The tank gauge sender for The mk1 petrol. Mine is working but it stays on full intill i got like 2/4 let then it pops down to The right level.
Post by FredTransit on Jun 13, 2016 10:06:49 GMT 1
Mk1 and Mk2 are the same mate, Ralph might have one. There are petrol and diesel though, with diesel being rarer.
Post by alexjohanssonswe on Jun 13, 2016 17:43:32 GMT 1
Ok. Ill try to Google a mk2 one. I have a petrol car. Thanks!
Post by jonochap on Jun 13, 2016 18:26:56 GMT 1
A general question, can the sender be taken out and cleaned to cure that?
Post by alexjohanssonswe on Jun 13, 2016 19:50:09 GMT 1
Thats what i want to try:) just wanna se how it looks first:) i dit that on my vw lt31 pickup, took it out and cleaned in and wiggled The moving parts a bit and after that it has worked fine
Post by alexjohanssonswe on Jun 19, 2016 20:44:57 GMT 1
Post by muttleymk2 on Jun 19, 2016 22:13:42 GMT 1
When I worked for Fords in the late 70's we always used 20/50, there were no other grades available in the workshop.
Post by alexjohanssonswe on Jul 1, 2016 18:54:43 GMT 1
Hmm. I might run 20/50 then. The only oil with "high" zink % i can get a hold of easy is gulf classic 20/50 so it would be The easiest thing. Last owner prob. Had 10w30 cus thats what i found an old can of in The car when i bought it.
Post by alexjohanssonswe on Jul 27, 2016 21:22:17 GMT 1
We are really enjoying the campervan! Me, gf and 2,5yo Elise is now 700km from home and loving the views the transit is offering us. All i could wish for now is better gearing for less rpm at higher speed but i guess thats more or less impossible. But when winter comes im going to tare down the v4 engine for a rebuild and electronic egnition convertion:) consumptiom is 1,18liters/10km. Way less then expected! But i newer go over 80km/h, i dont like the v4 screaming. I have a 911 for going fast and we'r not in a hurry:)
Btw went with 10/40 (had a 4liter can i the garage) oil pressure is low so im going to install one of those hi performance oilpumps when the engine is out.
Post by bimmerbrother on Oct 19, 2016 14:45:13 GMT 1
Beautiful looking van, I'd like to see more pics please!
