Post by muttleymk2 on May 11, 2017 22:03:17 GMT 1
They will all snap off
Post by FredTransit on May 11, 2017 22:06:07 GMT 1
Oooooo you're a brave man. We had a whole donor to lop bits off, still ended up with a couple of flat bits in the floor, where the rot was the same in both vans. It's under the wood floor though, so doesn't matter. Alex ended up with the driver's rear wheel arch off the donor too.
Post by irishtransit on May 11, 2017 22:06:27 GMT 1
Thanks for the cheerfulness mutts. Haha.i will soon find out.
Post by irishtransit on May 11, 2017 22:08:43 GMT 1
Well fred if i cant sort the chasis then i wont bother with her.
Post by mk1van on May 13, 2017 23:08:56 GMT 1
got any more pics of the rest of the van?
Post by irishtransit on May 14, 2017 18:55:16 GMT 1
got any more pics of the rest of the van? not yet as she's still under cover as funnily enough it's raining here in ireland.now isn't that unusual NOT.
Post by irishtransit on May 21, 2017 14:46:31 GMT 1
Well wheel arch off and muttley only 2 snapped off well not totally true,1 came out ok,2 snapped off and 2 came away with the bodywork. Now to cut the wheel tub off
Post by muttleymk2 on May 21, 2017 21:51:53 GMT 1
Result!
Post by mk1van on May 22, 2017 21:34:34 GMT 1
if your off work from wed this week the weather is to be sunny again....and in wexford it will be savage
Post by irishtransit on May 22, 2017 23:21:57 GMT 1
ye i see it's supposed to be good from tomorrow.the trouble i have i just can't find the enthausiasm to get out there to her.
Post by irishtransit on May 24, 2017 18:31:32 GMT 1
on closer inspection(that's all i've done)it would appear it is only the top inch and the lip that is rotten on the chassis but my question is.the inside is where it is rusty but not right thru so if i cut the rot out will it still be okay to weld from the outside if i get rid of most of the surface rust etc?
Post by dodgerover on May 24, 2017 21:20:04 GMT 1
If I'm understanding you right, then you're cutting out the rot then welding in new metal from the outside? That will be fine if your welder is turned up to get penetration.
Post by irishtransit on May 24, 2017 21:45:53 GMT 1
Cheers dodge.all i need to do is find my mojo.
Post by dodgerover on May 24, 2017 21:50:26 GMT 1
At least you'll be able to see the inside as well so should be easy to tell if the weld is penetrating ok.
Post by irishtransit on May 29, 2017 0:28:11 GMT 1
well got the doors and bumpers off today and she's not that rusty haha gonna make the inner rear valance and inner lower corners using the 2mm just so they last longer.hopefullyy start tomorrow weather permitting.
