Post by mk1van on May 29, 2017 19:45:37 GMT 1
some serious bodywork there to be done.....
Post by irishtransit on May 29, 2017 20:00:29 GMT 1
some serious bodywork there to be done..... there is but no so much cutting out as it's all gone lol.
Post by troppo on May 30, 2017 4:13:16 GMT 1
Strip it all out in the biggest pieces you can, but measure everything before you do (oops noticed you already have lol) cut, fold and form the chassis and subframe parts, you might need th get the beaver pannel rolled at a metal shop, do the bast of the heel tubs and then finish with the floor. Little by little and you`ll have it all done after a while
Post by irishtransit on May 30, 2017 15:32:17 GMT 1
Strip it all out in the biggest pieces you can, but measure everything before you do (oops noticed you already have lol) cut, fold and form the chassis and subframe parts, you might need th get the beaver pannel rolled at a metal shop, do the bast of the heel tubs and then finish with the floor. Little by little and you`ll have it all done after a while i know she's dropped so was planninning on doing the rear inner valance first and getting it level and then the inner rear corners and then work out and up keeping it all square with the inner panels.does that sound like a plan?
Post by irishtransit on May 30, 2017 17:58:41 GMT 1
Would anyone know the length of the inner rear valance as i cut mine off without measuring thanks to the wife being a bitch and annoying me before i started.
Post by bullsintransit on May 30, 2017 18:13:14 GMT 1
If you photo the bits you want measured I'll get dimensions off mine if needed
Post by irishtransit on May 30, 2017 19:00:51 GMT 1
If you photo the bits you want measured I'll get dimensions off mine if needed It's the length of the inner panel from the inner edge of the inner lower rear corners.i think its around 60 inches
Post by bullsintransit on May 30, 2017 19:28:50 GMT 1
If you photo the bits you want measured I'll get dimensions off mine if needed It's the length of the inner panel from the inner edge of the inner lower rear corners.i think its around 60 inches Right,width 163 cm(64.17 inch) plus a12 mm(half inch) fold at each end tacked to inner lower wing valences. Height 15.5 cm(6 inch),plus fold top and bottom,tacked to floor (top) and outer rear valance (bottom). On mine,taking a measure it's 62cm rearwards of the rear main crossmember(the one going crossways,just behind rear wheel arch). Sorry tapes metric!,if you want/need photos ask,not a problem.
Post by irishtransit on May 30, 2017 19:33:57 GMT 1
well i can't thank you enough.i'll get on tomorrow and make one up.should make life a lot easier with that in place as i can then work the corners etc as they are gone on the nearside.i might have to end up turning her into a van as around the windows is very rusty(pics tomorrow)plus i have no seats either
Post by bullsintransit on May 30, 2017 20:29:21 GMT 1
Forgot to say,all the folds are folded towards the front of van from rear,all look right angles.
Post by irishtransit on May 30, 2017 21:35:26 GMT 1
Well thanks to mr bull(sorry dont know ya name) i cut the panel out from the 2mm steel i have.thought id stick it in the vice with 2 lengths of angle iron as edges but by god is it hard to bend.i gave up after quarter of an hour and will try tomorrow.
Post by muttleymk2 on May 30, 2017 22:07:16 GMT 1
Try running the grinder disc edge along the line that marks the inside of the bend, dont cut too deep, it will make bending easier
Post by irishtransit on May 30, 2017 23:13:36 GMT 1
cheers mutts i knew you'd have a trick
Post by irishtransit on Jun 2, 2017 21:19:36 GMT 1
well made up the inner panel but need to make the relavant holes and today made up a repair panel for the chasis.it's not brilliant but i'm hopefully it fit with a bit of jiggling. what's left of chassis end old bit removed and new panel
Post by muttleymk2 on Jun 2, 2017 21:22:59 GMT 1
Very nearly professional there John
