Post by FredTransit on Jun 25, 2017 22:04:54 GMT 1
Let me know what you need off our donor. There's no driver's side inner rear arch. The driver's rear pillar is good. The passenger side is going at the bottom. Keep going.
Post by irishtransit on Jun 25, 2017 22:24:44 GMT 1
cheers fred will bear that in mind
Post by irishtransit on Jul 1, 2017 21:10:55 GMT 1
welded on the chassis panel.managed to get the height wrong but not a major issue as on the original at the end it drops down for the rear inner panel and as i made mine out of 2mm steel the height at the rear wold have been too high what with the floor and outter rear panel.welder was playing to start with and almost gave up.it's a fairly strong weld as i gave it a good old tug and nowt fell off(the panel that is!!!)
Post by muttleymk2 on Jul 1, 2017 22:13:55 GMT 1
Go on John the welder
Post by irishtransit on Jul 1, 2017 23:15:22 GMT 1
Cheers mutts.does it look ok to you
Post by irishtransit on Jul 2, 2017 19:22:41 GMT 1
got the rear inner panel on today.didn't bother to get the right shape at the bottom as 2mm is a pain to bend. just ecperimenting with imgbb for hosting
Post by muttleymk2 on Jul 2, 2017 21:19:06 GMT 1
Looks ok to me, its not gonna be a concours winner but as long as its solid who cares
Post by irishtransit on Jul 12, 2017 18:59:37 GMT 1
after a little advice please guys and gals.while i've been welding 2mm steel i have had my welder setting or 4 as 5 will blow fuses noe i'm gonna be welding 1mm to 2mm what setting is best? i'm thinking 2 possibly 3
Post by irishtransit on Jul 12, 2017 19:01:26 GMT 1
and what's happened to my pics on here too
Post by FredTransit on Jul 12, 2017 19:05:17 GMT 1
Post by dodgerover on Jul 12, 2017 19:20:47 GMT 1
Try it and see turn the power up till it burns through then turn it down slightly. Are you plugged directly into the mains? Using extention cables unless you use mega thick stuff is a recipe for welding problems.
Post by irishtransit on Jul 12, 2017 19:32:50 GMT 1
Try it and see turn the power up till it burns through then turn it down slightly. Are you plugged directly into the mains? Using extention cables unless you use mega thick stuff is a recipe for welding problems. ye unfortunately i have an extension lead.it's thicker than ya standard ones but that's as much as i know.
Post by dodgerover on Jul 13, 2017 9:46:47 GMT 1
Post by irishtransit on Jul 13, 2017 15:22:46 GMT 1
ye that looks like the one i have
Post by dodgerover on Jul 13, 2017 17:46:30 GMT 1
Which fuse is blowing? If it's the welder end (and the other end is fused) replace it with some 20 or 30 amp fuse wire. You won't be welding for enough time to have problems with heat build up just don't have the wire wrapped round anything or coiled up.
It's the voltage drop that's doing it.
