Post by irishtransit on Jul 13, 2017 18:09:47 GMT 1
will try it when i can be arsed to go out again(keep losing me mojo)
Post by irishtransit on Aug 2, 2017 16:28:59 GMT 1
Post by FredTransit on Aug 2, 2017 16:46:18 GMT 1
Did you know minibus and van door stays are slightly different? You can't lay the minibus door across the rear lights on a minibus. You can with a van, by flipping the stay out of the door. The minibus door stay is fixed in. I don't know if this makes any difference to the actual doors or hinges.
Post by irishtransit on Aug 2, 2017 17:07:08 GMT 1
cheers for that fred i would never have known that.i'll reposition mine when i can get the doors lined up.
Post by dodgerover on Aug 2, 2017 19:09:05 GMT 1
Red door needs to go closer to the pillar and up. Have you got the latching mechanism in the red door? Mine look a bit close if they aren't latched fully. Grey door might need to go a touch closer to the pillar
Post by irishtransit on Aug 2, 2017 19:36:24 GMT 1
I have the locks hear so ill put that on tomorrow.i can lift the red door a bit as the corner panel isnt connect at the bottom.will try to move the grey one
Post by dodgerover on Aug 2, 2017 20:54:00 GMT 1
You should be able to move them about on the hinge adjustments, there's a fair bit of movement available and you can always use a file to create more.
Post by irishtransit on Aug 2, 2017 23:56:21 GMT 1
You should be able to move them about on the hinge adjustments, there's a fair bit of movement available and you can always use a file to create more. never thought of that dodge
Post by irishtransit on Aug 3, 2017 19:36:46 GMT 1
done another little bit today as it's not raining(makes a change)so leaving the doors for now i attacked the n/s rear panel
Post by dodgerover on Aug 12, 2017 18:25:56 GMT 1
Are you doing gasless with the mig? The chassis bits you did looked like it was welding better. Still as long as it's solid it'll grind down and look fine
Post by irishtransit on Aug 12, 2017 21:00:24 GMT 1
yeh using gasless.it's taking fore3ver to do this corner and it don't help when i do stupid things like weld bits and realise i've forgotten to remove paint from another area.just got to weld the bottom of the outter panel in place and that's done but my drill bits are all blunt grrrrrr.
Post by irishtransit on Aug 26, 2017 18:50:16 GMT 1
can someone tell me what's gone wrong here and what i need to do to correct it please.i've pulled the bottom in with a ratchet strap but still don't line up and if a bend the outer corner it buckles on top.
Post by muttleymk2 on Aug 26, 2017 21:10:54 GMT 1
Hard to tell from them pics John.
Post by irishtransit on Aug 26, 2017 21:16:27 GMT 1
Basically mutts the bottom of the corner wont line up with the rear outter panel.i think the support bracket for the pillar is to wide and stopping the rear panel from lining up better
Post by mk1van on Dec 1, 2018 0:04:53 GMT 1
have ya sold this yet?
