Post by corktina on Nov 7, 2017 23:22:23 GMT 1
for swb mk2...someone on the net suggested 50 psi, that's way too high surely?
Post by muttleymk2 on Nov 8, 2017 22:40:27 GMT 1
40/45 psi
Post by corktina on Nov 12, 2017 23:28:02 GMT 1
thx for that. I had been putting in 35 or so but my garage reduced them all down to 30, and you'd need arms like Popeye to steer it so I increased it back. Steering seems sloppy since i got the track rod ends done, I wonder if it needs the tracking adjusted? Years ago we used to toe-in the wheels slightly buit the steering boxes are notorious for play so I don't really know which way to go. I'll increase to 40 or 45 and see if that improves things.
Post by FredTransit on Nov 13, 2017 13:26:39 GMT 1
I have never had a transit at 30. Even Camilla, a single wheeler. No idea where they got 30 from.
Post by muttleymk2 on Nov 13, 2017 22:59:51 GMT 1
Your steering should have toe-in of 0.5 to 0 mm that means it can be parallel or as much as 0.5 mm toed in. I find parallel gives the best drive
Post by corktina on Nov 14, 2017 11:45:16 GMT 1
they look pretty paralell, I'll check if I can find a ball of string :-) (old skool)
Post by corktina on Nov 14, 2017 12:46:53 GMT 1
can't find my string but with 45lb in the steering is much better,a bit bouncier perhaps. might reduce it to 40 later.
