jmh
New Star
Post by jmh on Nov 9, 2017 8:07:06 GMT 1
Hi all. Can anyone help. I have a mk1 transit 2.4 york diesel bull nose. 1973. I intend to fit a 2.5 di banana removed from a 1998 transit. I have the whole vehicle for spare. Can Antony tell me what I need to change in order to make the. We engine fit. ? All advice will be greatly appreciated JMH
Post by FredTransit on Nov 9, 2017 10:34:09 GMT 1
It's quite straightforward as they are the same basic block. You also don't have glow plugs on the DI. That's a banana isn't it? I am not sure if the York intake manifold will fit.
jmh
New Star
Post by jmh on Nov 9, 2017 13:25:16 GMT 1
[yeah it's the banana engine. Intake manifold ? Is there one that I need to get ?
Post by FredTransit on Nov 9, 2017 20:02:33 GMT 1
An early DI, with the air cleaner on top of the engine. Your York one may fit, ask Muttley!
Post by bambimk1 on Nov 9, 2017 21:00:12 GMT 1
York inlet manifold wont fit .You can use the exhaust one though,saves modding the zorst.You should be able to use the banana inlet and put the air box down on the chassis leg.You will have to move the washer bottle if so.
Post by FredTransit on Nov 9, 2017 21:20:22 GMT 1
We've put the air cleaner on top of the engine on the Mk2 before, using the early DI. manifold we once put the original air box at the side, it didn't look right.
Post by muttleymk2 on Nov 9, 2017 22:47:01 GMT 1
Yeah, wot Bambi said
Post by FredTransit on Nov 9, 2017 23:30:18 GMT 1
You can swap inlets though, and avoid siting the air box at the side of the engine.
Post by bambimk1 on Nov 9, 2017 23:52:48 GMT 1
We've put the air cleaner on top of the engine on the Mk2 before, using the early DI. manifold we once put the original air box at the side, it didn't look right. You wont be opening the bonnet too often to look in with a di
jmh
New Star
Post by jmh on Nov 10, 2017 8:34:02 GMT 1
Ok thanks for your advice. Mine is a lhd that I bought and shipped from Sweden. Really good solid body. The new donors engine come from a friend. An old ice cream van. So hasn't been worked hard for last 10 year. Do I need to modify the tunnel to fit the 5 speed box ? I'm new to the transit things. I normally do this with my old escorts. Any help much appreciated. JMH
Post by FredTransit on Nov 10, 2017 19:23:32 GMT 1
The type9 fits without changing the floor. The MT75 needs to have a new hole as the gear lever comes through the floor to the right of the original 4 speed. At least, that's on a RHD.
Post by muttleymk2 on Nov 10, 2017 21:59:51 GMT 1
If you are changing box as well you will need to modify gearbox crossmember and propshaft.
jmh
New Star
Post by jmh on Nov 16, 2017 18:49:02 GMT 1
Hello again people. More help will be needed. I had my man try to offer up the new engine and box today. He tells me the DI sump doesn't fit the mk1 crossmember!! Can anyone shed some light on what I need to do ?
Thanks in advance.
Post by muttleymk2 on Nov 16, 2017 21:43:13 GMT 1
You will need Mk2 Di mounts for the chassis and remove the Mk1 crossmember.
jmh
New Star
Post by jmh on Nov 18, 2017 21:05:44 GMT 1
Would this be the right place to sell the old york engine ? Would anybody be looking for one ?
