Post by jayneycam on Feb 5, 2018 9:12:21 GMT 1
Hi, looking for a screen metal surround section hopefully cut off a solid breaker...mine’s rotten underneath rubber
Post by muttleymk2 on Feb 5, 2018 22:49:29 GMT 1
They pretty much all are, I have replaced the whole screen surround back in the day but that panel is in short supply these days. What area is rotten, I can fabricate panels to fit
Post by jayneycam on Feb 13, 2018 0:18:51 GMT 1
Hi, Outside under the screen rubber is rotten and outside at bottom from screen to bonnet is rotten, then inside is rotten from screen to edge which meets the plastic dash panel so pretty much the whole panel inside & out ! ....my welder did say he could fabricate something but will cost a fair bit for his time to do so 😢 which is why i need a decent panel cut from a breaker, but if like you say they’re all bad then i will just have to bite the bullet and get him to fabricate that panrl thank you 👍 the whole side from rear quarter to & including the side panel is completely rotten so far too 😢 so she needs loads of welding already & thats without anything else uncovered lol
Post by muttleymk2 on Feb 13, 2018 22:34:02 GMT 1
Thats old Transits for sure, whereabouts are you, I may be able to give a cheaper qoute for the work
