Post by rick on May 19, 2018 8:27:08 GMT 1
Is it ep80 gl4 for the overdrive gearbox and am I right that it's 90 gl5 for the diff ?
I've asked this before and have both on the shelf but can't remember which was which sorry 😊
Gear oil
May 19, 2018 13:59:10 GMT 1
via mobile
rick likes this
Post by dodgerover on May 19, 2018 13:59:10 GMT 1
GL5 is ok in the diff but not the box from memory, you can go thicker than EP90 if needed in the diff. O/d box might need something different to the normal box GL5 is not suitable for the 4 speed.
Post by rick on May 19, 2018 16:40:32 GMT 1
Thanks for the info mate I did buy the ep80 for the standard box then ☺ should it be ok in the overdrive does anyone know?
