Post by potentialproject on Jul 28, 2018 14:54:37 GMT 1
hi everyone, was planning on doing the 5 speed conversion on my pickup. Just getting parts at the moment. My pickup is lhd, and the gearbox I was going to buy is from a Rhd , is there any difference ? It's got the cable drive for the speedo. Well looking forward to having 5 gears, and reverse would be an absolute novelty. Cheers
Post by sleepy on Jul 28, 2018 17:15:23 GMT 1
not 100% sure but I think the rhd gearstick comes out of the other side of the box as I'm certain I've seen lhd floor mats with the hole further to the left, i could be wrong though😊 are you going type 9 or mt75 box
Post by potentialproject on Jul 28, 2018 19:13:31 GMT 1
I wanted mt75 box, reading on here it seems it's the best way to go. I wouldn't have thought there's any difference, but I don't know for sure.
Post by sleepy on Jul 28, 2018 19:33:56 GMT 1
I've got an mt75 and very happy with it Speedo is well out though
Post by potentialproject on Jul 28, 2018 20:09:52 GMT 1
Yeah, it's definitely, the way I want to go, I,ve read somewhere type 9 , wear out quicker, something to do with bearings in them. When you said , about the gear stick , coming out in a different place, if it's only a couple of inches, I wouldn't think it would affect driving, regarding bolting gearbox to York engine, will it bolt straight on?
Post by sleepy on Jul 28, 2018 22:22:00 GMT 1
mines bolted to a pinto with an adaptor plate I'm sure someone will be along soon that will know for definate
Post by muttleymk2 on Jul 28, 2018 23:26:02 GMT 1
Mt 75 gear lever is in the middle of the box, you will need an LHD clutch cable to suit the MT, the box should mate to your York as its for a Di and they have the same bolt pattern.
Post by sleepy on Jul 29, 2018 6:56:42 GMT 1
told you someone would be along😄 that's right the type 9 stick comes out the side good luck with the conversion👍
Post by sleepy on Jul 30, 2018 20:25:31 GMT 1
Post by potentialproject on Aug 2, 2018 0:01:41 GMT 1
Thanks for the feedback, it all helps. Had a look at the kit on eBay, it's a good kit, saves all the running around for bits, when you add the price of new clutch, and bits and pieces , it's not cheap job is it.? Convenience versus cost , something to think about. Thanks
Post by muttleymk2 on Nov 27, 2018 22:59:51 GMT 1
What engine and gearbox do you have at present and do you have a one piece propshaft?
Post by muttleymk2 on Dec 7, 2018 22:58:50 GMT 1
If its all stock with one piece propshaft, you will need a Mk3 Transit SWB two piece propshaft and you will have to fabricate a carrier for the centre bearing. Pinto and Mt75 box will require engine moving back to allow clearance with the stick flat front, also you will jave to make a new hole in the floor for the gearlever.
Post by jonochap on Dec 11, 2018 18:42:33 GMT 1
I know someone who does a wicked Granada engine install! I still have reservations over a type 9 but the mt75 seems to work well be sure about why you want to change the gearbox though😁
Post by muttleymk2 on Dec 16, 2018 22:25:37 GMT 1
It does go, just not easy Looking at your pic there, do you still have pedals thru floor? If you do then you will need to convert to cable clutch for the type 9.
Post by muttleymk2 on Dec 17, 2018 22:51:39 GMT 1
You will need to convert to facelift (post 1970) pendant pedals for Mt or Type 9, this means you will also have to fit master cylinder and servo from the later van. You will have to re pipe the brakes also as the later vans are dual circuit brakes.
