Post by fortyeight on Oct 26, 2012 11:16:33 GMT 1
hi im after a master cylinder and servo ,the one with 2no/ filler screw caps on the resovoir to fit a mk2 1985 2ltr pinto engine,cheers
Post by gpw on Oct 26, 2012 12:03:57 GMT 1
hi im after a master cylinder and servo ,the one with 2no/ filler screw caps on the resovoir to fit a mk2 1985 2ltr pinto engine,cheers Why please?
Post by FredTransit on Oct 26, 2012 12:56:47 GMT 1
I think he's having brake problems! Like I said in the PM mate, the whole Mk3 servo/master will fit. Also I think it's bungle who found an LDV one works though dunno which one. Either way you are looking at new pipes unless you go for like for like
Post by gpw on Oct 26, 2012 15:12:52 GMT 1
. He's very specific about the type he wants Fred, so I am curious why.
Do you know the ratios for the servos for a Mk1, an Mk2 and an Mk3 please Fred?
Post by FredTransit on Oct 28, 2012 18:53:15 GMT 1
as far as I know there isnt a lot of differece between em, when I bought the Mk3 one for a LWB chassis cab I just specified LWB Some mention the model in case it does make a differenxe
Post by gpw on Oct 28, 2012 19:06:17 GMT 1
. Wouldn't surprise me Fred. .
Post by fortyeight on Oct 29, 2012 13:22:44 GMT 1
hopefully i found one,its a ( vertically system )as mine is,except it as one screw top filler,mine as 2 but i would think it will do £20 not much to lose if it dosn,t ill let you no when its beed tried and tested
Post by gpw on Oct 29, 2012 16:27:39 GMT 1
. Your two cap reservoir may well fit FortyEight.
I suggest that when you fit your replacement, you use something to hold the reservoir on - say a zip tie.
I also suggest you flush your replacement through with loads of NEW brake juice. Also, it's a good idea to wash your reservoir out with fresh juice.
Post by fortyeight on Oct 30, 2012 16:01:30 GMT 1
will do
