Post by bullsintransit on Nov 27, 2018 20:29:14 GMT 1
Can remember seeing beetles with coloured rubbers, but cant see nothing now on west coast metric but black, then it gets expensive getting someone like ‘extrudaseal’ making it up in most RALs, but they supply big companies.
To an untrained eye wouldn’t white window rubbers on a white van just look like the rubbers had been painted, but to a trained eye look like white rubbers? 🙂
Post by dodgerover on Nov 27, 2018 20:37:27 GMT 1
Are you fitting metal panels in place of the glazing but secured with the rubbers? I think you may have an issue with the thickness of the metal compared to glass but I may be wrong. I cut metal panels then bonded them into the openings using PU body adhesive aka tiger seal. I did originally plan on welding them in flush with the sides but the chances of me causing massive distortion were too high.
Post by dodgerover on Nov 27, 2018 23:33:15 GMT 1
