widge
Post by widge on Feb 7, 2020 14:37:31 GMT 1
My Camper is a French Registered 1981 Pilote conversion, I am currently trying to apply for the French equivalent of vintage car status, I have just had my request sent back because there is an inconsistency between the Carte Grise (French V5 registration Document) the docs give a number of GBVCAC56680 but the chassis plate has the following info, I don't seem to be able to translate either using standard VIN information (unless I am misunderstanding the format) so I am wondering if this is a proprietary plate from the Camper Van Supplier in which case maybe it isn't an error.
I have written to Pilote to see if they have records going back that far, but as yet haven't heard anything.
thanks in advance for any suggestions.
Dave
Post by muttleymk2 on Feb 7, 2020 22:53:18 GMT 1
Thats not a Ford VIN plate, it should be in the door step, there is also one on the bonnet slam panel above the headlamp.
widge
Post by widge on Feb 7, 2020 23:44:02 GMT 1
Thats not a Ford VIN plate, it should be in the door step, there is also one on the bonnet slam panel above the headlamp. Hi Thanks for that, there isn't one under the bonnet, but I have found the one on the door step, I cannot believe that I didn't spot it before. I checked the drivers side, but not the passengers side, I must be getting senile in my old age.
Dave
Post by muttleymk2 on Feb 8, 2020 23:00:45 GMT 1
You and me both
widge
Post by widge on Mar 5, 2020 7:53:25 GMT 1
Good news today, I received an email from the "Federation Francaise des Vehicules d'Epoque" with a certificate saying that my application to have our 1981 Ford Transit Camper Van classed as a "vehicule de collection" (vintage car status) has been accepted, one advantage is that the CT (French MOT) will be only every 5 years and it will be tested as a vehicle of that age and not treated the same as a modern vehicle. so I know that we will get at least another 5 years use out of her.
Dave
Post by muttleymk2 on Mar 5, 2020 23:32:31 GMT 1
Excellent news
