Post by peeteeb on Dec 21, 2020 1:31:51 GMT 1
Morning , I am in the middle of replacing the belts on my engine.Im considering doing the valve clearances,downloaded and scanned the manual recommended here but can’t find any mention of the clearance! .can anybody put me right?. Many 😊
Post by muttleymk2 on Dec 21, 2020 22:06:53 GMT 1
Inlet 0.20mm exhaust 0.38 mm cold
Post by peeteeb on Dec 21, 2020 23:48:48 GMT 1
Thanks Muttley! . As you are a veritable fountain of Ken, can you tell me where the pre- heat is?.i have no idea. There is glow plug and it is a diesel...so I’d expect something...the butchery of the wires may have dispatched it , are there a couple of wires I should look out for? Brown and something seems favorite!!.
Post by muttleymk2 on Dec 22, 2020 22:10:07 GMT 1
Some Yorks have a heater in the inlet manifold (single) or glow plugs (4) in the inlet. There is a glowplug timer/ relay on the drivers inner wing near the starter.
Post by peeteeb on Dec 29, 2020 11:49:42 GMT 1
Great,many thanks..hope you had a good Christmas over there,I’m back and about to get stuck in.have noticed the diff oil is leaking from the seal at the front...do I have to go to ford for the seal or is it generic?. Have a great new year!
Post by muttleymk2 on Dec 29, 2020 22:33:40 GMT 1
Seals can be got from Ralph, remember you will need a new crush washer for the pinion nut
Post by Ralph on Dec 30, 2020 7:41:18 GMT 1
Yes I have new pinion seal but I think im out of stock of crush washers but I will have a look.
Post by peeteeb on Jan 19, 2021 22:05:49 GMT 1
Ralph! Pete here. Any update on the seal and washer situation?. Might you be able to post to Portugal!?.Also annoyingly,today I removed the windscreen wiper mechanism to overhaul it and as I pushed the tiny C clip from the external arm the wind blew it away! Go figure!,.might you have one??!.If you only have the seal ,I am still interested!.Post to Portugal is around a tenner I 🤔
Post by peeteeb on Jan 19, 2021 22:07:17 GMT 1
Is the crush washer copper usually? If so heating it till cherry red for five minutes should do the trick!.
