widge
Post by widge on Apr 10, 2021 22:49:25 GMT 1
Hi We have a 1981 Ford Transit Camper, a few years ago we were having a good run in her and she was going very well (she was sat quite comfortably on 100km/h) until suddenly there was a knocking from the engine and she started producing smoke from the exhaust, thinking that it was something terminal I pulled over and got the recovery people to pick her up and get her back to the house, eventually had time to look at what was going on, I check various things including compression (which was roughly the same on all cylinders) but basically couldn't find anything wrong and she started and appeared to run fine.
Since then I have done a few thousand kilometres without problem, today the same thing happened, again I was sat comfortably at about 100km/h for about 10 minutes and started to get bad knocking from the engine and lots of smoke I had nowhere to pull off but backed off as much as I could and the knocking stopped along with the smoke and she got me the 30km home without further incident including some long climbs.
I am guessing that under certain conditions the crank case is pressurising and pushing oil past the rings causing the knocking and burning oil, but any suggestions of a likely cause.
Dave
Post by Ralph on Apr 11, 2021 7:36:30 GMT 1
If its diesel it sounds like a sticking injector to me.
widge
Post by widge on Apr 11, 2021 9:50:37 GMT 1
If its diesel it sounds like a sticking injector to me. Hi Thanks for the reply, yes it is a 2.4 york engine, excuse my ignorance but how does an injector stick and why? Dave
Post by muttleymk2 on Apr 11, 2021 21:45:48 GMT 1
What colour is the smoke, is the oil level correct?
widge
Post by widge on Apr 11, 2021 23:28:06 GMT 1
What colour is the smoke, is the oil level correct? hi I will check the oil level but i think it is ok, as far as the smoke, difficult to say, it was raining and there was quite a bit of spray as well but i dont think that it was particularly dark.
Post by Ralph on Apr 12, 2021 6:18:10 GMT 1
An injector can stick so instead of spraying the diesel it will just dribble in so will not ignite. When It does it sounds much like a big end has gone with a loud knocking. I have had it happen to me & the symptoms you gave were exactly the same.
widge
Post by widge on Apr 12, 2021 13:04:28 GMT 1
An injector can stick so instead of spraying the diesel it will just dribble in so will not ignite. When It does it sounds much like a big end has gone with a loud knocking. I have had it happen to me & the symptoms you gave were exactly the same. Hi
That is encouraging, I am not sure how available injectors are for that motor, but I believe there is somebody fairly local to me that reconditions them, I will find out.
Thanks again
Dave
Post by muttleymk2 on Apr 12, 2021 21:27:40 GMT 1
As Ralph is suggesting, a dribbling injector will give these symptoms. If it is an injector then the smoke will be grey/ white.
Post by Ralph on Apr 13, 2021 6:49:56 GMT 1
Try putting an injector cleaner addictive in the tank.
widge
Post by widge on Apr 16, 2021 13:15:46 GMT 1
Thanks again
Dave
Does anyone know which Injectors the 2.4 York motor has, I have emailed the local guy and he cannot quote me a price without knowing which injectors it has, or does this motor have more than one type depending what they were using when it was manufactured?
Otherwise I will have to go and see him.
Post by muttleymk2 on Apr 16, 2021 21:30:02 GMT 1
Best to take injectirs to him.
