Post by peeteeb on May 18, 2021 18:40:55 GMT 1
Post by muttleymk2 on May 18, 2021 22:13:47 GMT 1
Not a serviceable item then eh
Post by Ralph on May 19, 2021 6:18:19 GMT 1
I have a customer who replaced the O rings in his.
Post by peeteeb on Jun 7, 2021 21:58:34 GMT 1
Thanks Ralph ,yes the O rings look easy enough but the main piston seal might be more tricky,I’ve seen similar in some of my motorcycle master cylinders,but until I get my hands on all my bits and pieces I won’t be able to tell,It will be the O rings which probably seal the piston so might experiment with the O rings,main problem is getting air into the system below many bends in the pipes over the axle when you separate it,I think one of those easy bleed kits might be needed! ))
