Post by shawn74 on Jun 4, 2021 22:48:06 GMT 1
Had a problem last year where my mk2 2.4 Diesel would bog down and loose power after about 20 mins or so on the road..so I checked and replaced the Diesel filter and air filter (Cheers Mutely)...now I still have the same issue only this time it looses power then completely cuts out. When I try starting it struggles to start and slowly gets back up to normal running.....any thoughts?
Post by muttleymk2 on Jun 5, 2021 22:01:26 GMT 1
Sounds like air getting into the fuel before the injection pump. Check all your connections between tank and filter.
