Post by jonochap on Oct 29, 2012 22:30:23 GMT 1
Mine ischt kapput!!!
Post by gpw on Oct 29, 2012 23:36:36 GMT 1
. They are usually revivable Jono.
Exactly what's wrong with it? .
Post by jonochap on Oct 29, 2012 23:57:23 GMT 1
The only symptoms i know is that the brake is down to almost nothing with the engine off or on. My friend the mobile mechanic has sent me on a mission to find a new one...
Post by gpw on Oct 30, 2012 9:00:28 GMT 1
. Do you wish to learn how to find out what needs fixing Jono? .
Post by jonochap on Oct 30, 2012 9:23:47 GMT 1
Please not sure it will help this time but its all good learnin, just please use small words and dont talk too fast that would be great though
Post by gpw on Oct 30, 2012 11:14:19 GMT 1
Post by FredTransit on Oct 30, 2012 11:59:42 GMT 1
You can fit up to a Mk3 mate, and bungle said even an LDV one. You will need new pipes though.
Post by gpw on Oct 30, 2012 15:27:14 GMT 1
Pity to spend all that hard earner when seals and cylinders appear available though Fred?
What's the chance it simply needs bleeding?
Post by jonochap on Oct 30, 2012 15:57:32 GMT 1
Right...thanks gpw, have had a look at the sockets, nope sorry dont own anything that small...yes i am happy to take off a wheel but cannot jack this honey up at the moment as have no jack or axle stands yet (other problems keep getting in the way of such purchases) The fluid level has not dropped and does not need topping up which is why i would think that mvm (the mechanical medicine man who helps me try and understand puk) thinks its a whole server issue... Regardless, i am intrigued and would like to know more...when we change the servo over i will try and get some pics to go with what you are about to tell me so that maybe others can benefit too...and i am not so sure the forthcoming servo wont need tlc as well
Post by gpw on Oct 30, 2012 16:11:12 GMT 1
. From the information you have given me, which is that the problem is the same with or without the engine running it ain't your servo Jono. If it is, you can replace parts.
Your brake works without the servo. Servos only make the brake pedal easier to push.
Every thing you've told me makes me think your brakes only need bleeding.
Post by gpw on Oct 30, 2012 16:13:26 GMT 1
. I forgot to ask Jono.
What numbers are written on your master cylinder please?
Post by jonochap on Oct 30, 2012 16:36:09 GMT 1
Thanks gpw, been to check, cant see a number anywhere but its a lockheed single reservoir if that helps???
Post by gpw on Oct 30, 2012 16:49:20 GMT 1
Yes, they can be difficult to see Jono.
What yeqr is your Transit please?
How many steel pipes come out of your master cylinder please?
Post by gpw on Oct 30, 2012 18:00:58 GMT 1
Regardless, i am intrigued and would like to know more...when we change the servo over i will try and get some pics to go with what you are about to tell me so that maybe others can benefit too...and i am not so sure the forthcoming servo wont need tlc as well Spot on Jono.
Post by gpw on Oct 30, 2012 18:26:39 GMT 1
Does your look like this Jono?
